Cylinder head help please...
Old Mar 31, 2016 | 04:25 PM
turbo1spunn's Avatar
Default Cylinder head help please...
I reacently bought a 96 accord lx 2 2l and kept having to adjust the valves when i noticed to bolts that hold the rocker arm assembly down were broke off inside the head. So i tried ez outs and they just broke so i replaced the head itself. Bought new intake, exhaust, and head gaskets but qhen i start the car it smokes white smoke really bad and doesnt ever go away. Also when i try to accelerate its boggs and loses power. What can it be ive taken yhe head off 5 times to check everything out and still dont know what the problem is.
Old Mar 31, 2016 | 05:18 PM
oldschoolmaster's Avatar
Default Re: Cylinder head help please...
White smoke is coolant or water
Headgasket isn't sealing
Have u had the head checked for straight ness
Old Mar 31, 2016 | 08:19 PM
Ive bought two heads and took to machine shop and they both are good the only thing i can think of now is the pins that sit in the block are to long creating a gap
Old Mar 31, 2016 | 10:53 PM
motoxxxman's Avatar
definitely headgasket leaking. are you reusing the headgasket? dont. also, are you torquing the head in the proper sequence, stages, and to proper torque spec at each stage with a torque wrench?
Tecotimj
Aug 24, 2017 03:43 PM
TypeRMOBBiN209
May 1, 2009 04:21 AM
touintegra1
Oct 6, 2008 02:18 PM
DS_Vtec
Nov 18, 2007 08:08 PM
ITSTOCK
Apr 19, 2004 12:53 PM
