Chipping an Automatic?
Old Apr 22, 2012 | 06:45 PM
VTECwalka's Avatar
Default Chipping an Automatic?
I have a 94 civic ex coupe with a swapped D16Z6 I see allot of chips are for manual only. Is this true? it can only be done with manuals or can i use it in auto? And what else would i need other than the chip and socket? Havn't messed with my ECU at all really and Im sure its still the Stock p28
Old Apr 22, 2012 | 06:57 PM
civicexkid1's Avatar
Default Re: Chipping an Automatic?
people need to stop talking about chips that say therell get a million hp. unless your geting a hondata or someother type of engine managment then dont post questions like this there all over this place. on a stock engine a chip wont do anything but blow your enigne. if you get a tune with hondata youd get maybe 10-15 hp. your driving a stock sohc which wont make power with out a turbo and money. and your driving an auto so drive it like it was built. a cheap reliable car that gets good gas milage.
Old Apr 22, 2012 | 07:37 PM
zcme's Avatar
To actually answer your question. Yes a stock automatic ecu can be chipped and tuned. Try to find a local tuner in your area. The only difference is you have to have a automatic bin iirc. Hondata works but you could also use neptune, ectune or crome.
To tune the car yourself you will need to chip the ecu, have a base bin, rom editor software, dataloger, chip burner and a wide band. Its also nice to have an emulator and dyno time.
Getting a basemap (chip) off anyone is imo a waist of time. Its a stab in the dark getting a custom tune is always better.
Old Apr 24, 2012 | 04:34 PM
VTECwalka's Avatar
Thank you for an answer and not you're opinion on my car. It was bought for me as my first car and i have no problem driving it as an automatic still wins at stop light races. Would you happen to know how much money it would take to custom tune my car?
Old Apr 24, 2012 | 06:07 PM
zcme's Avatar
Depends on the tuners rates.
Old Apr 24, 2012 | 08:11 PM
Bix VT's Avatar
You already have the ECU, so that's $100 saved. Here's the cost of materials needed (we'll say Neptune/Demon to keep it simple):
Chipping kit: $16 http://www.moates.net/honda1-honda-e....html?cPath=69 *All this does is create a place to plug chips/circuit boards into*
Neptune/Demon combo pack: $399 http://www.moates.net/demon-hardware....html?cPath=69 *There are other options out there, but Neptune has the best customer service and support, which is essential for someone just entering the tuning world*
Wideband oxygen sensor: ~$200 depending on brand and style desired. This, often combined with datalogging, tells you what part of the tune needs to be adjusted. Tuning without one is basically guesswork.
You will also need a laptop with a USB port to tune with, if you don't already own one.
It should also be tuned on a dyno. Costs vary, but expect around $500 to have someone else tune it for you, or around $150/hour to tune the car yourself, on their dyno.
Old Sep 25, 2012 | 06:26 AM
VTECwalka's Avatar
Thanks guys. For some reason my engine cost more than some of the DOHC vtecs so i may get it swapped out again and where i am i can get a manual for under $500 fly wheel and all. so i may do that then chip it. But again thank you.
Old Sep 25, 2012 | 07:22 AM
HRTuning's Avatar
It's worth noting that the NepTune/Demon combo comes with a chipping kit, so you don't need to buy that separately.
Old Jan 4, 2023 | 02:28 PM
Ved9o's Avatar
He was just asking a question bro like chill, it might be for the future and hes planning out a build so chill out. i have the same question as him and my cars stock but im planning for, the future.
Old Jan 4, 2023 | 02:57 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Always good to look 11 years into the past to plan the future.
Old Jan 4, 2023 | 03:01 PM
Ved9o's Avatar
Haha well in my case i like to research and save parts that work well together when i start something than when im midway through my build
Barney TSX
Acura TSX
26
Oct 11, 2013 09:16 AM
teg01type-r
Jan 3, 2007 03:20 AM
christoble
Dec 4, 2004 05:21 PM
SiR 621
Feb 26, 2004 05:40 AM
Big Teggie
Jun 23, 2003 05:41 PM
