chipped p28
Would it be to late to have hondata do something to it and would be better then the jet chip? all jet dose is bump everthing up like timing and advance everything? at least hondata is tuneable....
YOu can't reprogram a chip. Hondata is an add-on EMS that installs in the ECU. It's not cheap and will require additional tuning. Preferably by someone that knows how to tune. That will most likely incur an additional expense.
Since you never mentioned what mods are done to your engine there's a good chance Hondata would be overkill and not cost effective.
Contac Phearable and have them burn you a better chip to your specs. $35.
thirsk66
Feb 2, 2015 10:41 AM
