cel problems
Old Dec 1, 2011 | 03:47 PM
SAXON's Avatar
Default cel problems
well this section of the forum has some of the smartest people in it so i figured i would post my problem here
car 2000 civic si
harness: 2000 civic si
jumper harness
chipped p75 for iab control and jdm gsr
i am throwing code 21, threw the ecu on the moates tester and no code 21 through that
so i tested continuity from the solenoid to a4 and had continuity
i then tested the solenoid and it worked
I rewired directly anyway to see and i cant get rid of code 21.. is it possible to have a cel in the car and not on tester? I am dumbfounded and just want this problem resolved
cel comes on without starting the car and the key in the on position
thanks for any help
Old Dec 1, 2011 | 11:11 PM
mouab18c1's Avatar
Default Re: cel problems
Your ecu might be at fault.
Old Dec 2, 2011 | 04:51 AM
Type-GS-R-Turbo's Avatar
Your solenoid might have an internal short, try changing it and/or measuring the resistance to the block from the wire. I don't have my service manual in front of me, but there is a certain range of acceptable values for the resistance to ground.
hondatek614
Mar 13, 2010 04:08 AM
1sikhatch
Jan 31, 2010 09:06 AM
skaternak
12
Aug 13, 2009 08:39 PM
mrchris1979
Jan 10, 2008 09:21 AM
3rdGteg
Oct 18, 2002 08:48 PM
