Bosch saturated injectors
Old Mar 22, 2009 | 04:55 PM
slowwhitehatch's Avatar
Default Bosch saturated injectors
need help setting these injectors with a aem ems i have the data supplied with the injectors
just can't find how to set it on the aem ems.
Old Mar 22, 2009 | 05:46 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Bosch saturated injectors
ok so you just need someone to help you on the EMS side of it.
Old Mar 22, 2009 | 09:06 PM
mtber's Avatar
Contact the vendor you bought them from. Hopefully you bought them from a vendor that can actually provide you with support :-)
Old Mar 23, 2009 | 04:28 PM
tech7427's Avatar
set crank injector time table to around 150-180 and the settings to input for the injector dead time can be found under SETUP>Injectors>Primary>Batt Offest Table. there you can input the values. it only give you even battery voltage but aem can interpolate the odd batt voltage values
slowwhitehatch
Engine Management and Tuning
Mar 23, 2009 04:29 PM
underpressure02
Feb 1, 2006 03:27 PM
m3bluegsr
Jul 7, 2004 07:07 AM
