BARO error code /atmospheric pressure sensor
Hey guys need some help
I bought a built b16 turbo from a friend, the car ran fine until I connected my laptop to the hondata s300, saved the previous tune(8 year old tune) as soon as I did it the BARO code appeared and the car doesn't run animore, I have already desabled the injector error/knock error and atmospheric pressure error in the "misc" parameters and it's the same, don't know what else to do.... The car wasn't connected to any pc or Smanager in 8 years is it possible some kind of actualisation in some parameters occured? Ps:it's a usdm p28 if not mistaken |
Re: BARO error code /atmospheric pressure sensor
In all likelihood, the tune is now corrupted. Same thing happened when I bought a car that had a tune from several years past, tried to upload/download it and car would no longer run.
Unfortunately when jumping so many versions of Smanager, it is not able to correctly translate the calibration that was created on a much older version. The tune you download will be corrupt in the newer Smanager version, then when you upload it back to the ecu the old calibration is lost and you have overwritten it with the corrupted tune. Do you know what version of S300 it has? You will probably need to get it retuned completely. If you want help setting up a new base map to get the car running/driving at least, let me know. |
Originally Posted by 2x0
(Post 51898253)
Green = v1 Red = v2 White = v3 If it's a v1, PM me, I can help, and probably recover everything too |
Originally Posted by motoxxxman
(Post 51898270)
Yes, this.
Green = v1 Red = v2 White = v3 If it's a v1, PM me, I can help, and probably recover everything too I knew you could fix the dead battery issue on the V1, but you can recover a calibration once it is overwritten? :o |
(Post 51898306)
And If I'm able to pull anything from the board, there's a possibility I can convert it to a non-corrupt map with current firmware and software versions. PM me if interested edit: I worded this thinking you were the OP. |
(Post 51899123)
If you saved the original file, you can email it to me, and I can recover it from that. Doesn't matter if you saved it before or after trying to upload back to the s300.
And If I'm able to pull anything from the board, there's a possibility I can convert it to a non-corrupt map with current firmware and software versions. PM me if interested edit: I worded this thinking you were the OP. Your services would have saved me a ton of headaches, and money, a couple of years ago. Might come in use again someday. |
