b18c1 with p2t ecu.
Old Aug 25, 2011 | 10:55 AM
scott_turner's Avatar
Default b18c1 with p2t ecu.
Just put my gsr motor in my em1. Got a chipped p28 from phearable.net . The car pulls hard with the p2t , but not with the p28. After driving for about 35 miles, the car doesn't want to idle and when it dies it doesn't want to crank. If I put the p2t back in it cranks right up, and idle fine. Anyone have any ideas?
Old Aug 26, 2011 | 09:51 AM
mouab18c1's Avatar
Default Re: b18c1 with p2t ecu.
Contact phearale.net about your ecu.
Old Aug 26, 2011 | 09:59 AM
mtber's Avatar
We already replied to your email.
Please try unplugging your evap purge solenoid to see if it resolves the issue(s).
Some obd2 vehicles require you to do this when using an obd2 to obd1 harness, otherwise you will have issues such as the one you described.
If the issue ends up being the ecu which is doubtful, we will gladly replace the unit.
Old Aug 26, 2011 | 11:23 AM
that fixed the idle issue, but the p2t still pulls harder. i am planning on getting it tuned anyway. thanks phearable for the great customer service.
Old Aug 26, 2011 | 12:51 PM
mtber's Avatar
Feel free to email us if you want to try another basemap. The p2t shouldn't "pull" harder.
The ecu we provided likely has a smoother vtec transition making it feel like it doesn't pull as hard, however on the dyno it likely outperforms the p2t.
boostgoblin
Engine Management and Tuning
Dec 27, 2017 07:51 PM
KiNGDEE206
Aug 29, 2016 08:58 AM
mikeunreal2
31
Mar 12, 2006 10:28 PM
BeerBaron105
Jun 7, 2005 02:22 AM
89_crx
Apr 18, 2005 06:26 PM
