AEM Series 2 base cal
Old Mar 13, 2011 | 05:34 PM
AssHammer's Avatar
Default AEM Series 2 base cal
Looking for an AEM (10-6040)series2 base cal for a 94GSR. Converting from series one is hit or miss.. mostly miss.
Or any good info where i might be able to locate one to work with.
Old Mar 17, 2011 | 08:17 AM
Rtype16's Avatar
Default Re: AEM Series 2 base cal
With the conversion script in the latest software it does a pretty good job at converting it. Although you can start with the supplied base cal and work from there. You can also use the supplied base cal. Copy over your fuel table, start tables, ignition and make sure your micro sec per bit is the same.
H22AJSPEC
Engine Management and Tuning
Jan 11, 2014 10:45 AM
rocket06
Apr 14, 2013 09:25 PM
xxjonxx4
Sep 25, 2012 03:36 PM
mygoldeneg
Mar 19, 2012 06:49 PM
