14.9-15.1 too lean?
Old Apr 8, 2012 | 08:24 PM
Bendito's Avatar
Default 14.9-15.1 too lean?
Just bought a civic with a b18c1 with type r pistons, skunk 2 valve train & stage 2 cams. Its tuned conservative on hondata, the air fuel gauge stays steady at about 14.9-15.1 all the time (except on cold start, it fluctuates). I was told this could be dangerously to lean.. Should it be closer to 14 for safe daily driving?
Old Apr 8, 2012 | 08:56 PM
Bix VT's Avatar
Default Re: 14.9-15.1 too lean?
Does it read that while at WOT?
GagnarTheUnruly's Avatar
That's great for partial throttle. At 50%+ throttle what does it read?
Old Apr 9, 2012 | 02:01 AM
civickiller's Avatar
from the left first 3 columns 15
next 3 14
next 3 13
Old Apr 9, 2012 | 07:23 AM
Bendito's Avatar
Yup, 15.2-15.3
Old Apr 9, 2012 | 07:24 AM
Bendito's Avatar
Anything 50+ it reads 15.2-15.3. When I let off the gas or just idle at a light it stays between 14.9-15.1
Old Apr 9, 2012 | 07:26 AM
Bendito's Avatar
It's all over the place though when it's warming up in the morning.
Old Apr 9, 2012 | 07:43 AM
Bix VT's Avatar
At WOT you want closer to 13:1 for the best power.
Old Apr 9, 2012 | 07:54 AM
Bendito's Avatar
So it's way to lean than. I was told it's "dangerously" too lean.
Old Apr 9, 2012 | 09:01 AM
15 is getting to the danger zone. It sounds like you are probably safe around town but I'd keep off the throttle until you do a WOT tune.
Old Apr 9, 2012 | 10:56 AM
Bendito's Avatar
Thanks.. Gonna have it adjusted, now I need a good tuner in south florida.
Old Apr 9, 2012 | 03:33 PM
ennah's Avatar
Plenty of Tuners in South FL to choose from.
Old Apr 9, 2012 | 03:38 PM
Gunmetal_B20_Hatch's Avatar
What wideband is it?
Old Apr 9, 2012 | 03:41 PM
tuck1crx's Avatar
bump up fuel pressure a bit and ull b fine
Old Apr 9, 2012 | 04:25 PM
yes itll drive ok but your wasting a whole lot of gas or itll run a little lean
have it tuned properlly
next 3 14
next 3 13
Old Apr 9, 2012 | 05:41 PM
Bendito's Avatar
AEM Digital UEGO
Old Apr 9, 2012 | 06:34 PM
HdeucedeuceA's Avatar
It's not necessarily dangerous but it will run hotter compared to a richer A/F. Untuned, modified AP2's run this lean with zero issues. I'd shoot for 13-13.5 though.
Old Apr 9, 2012 | 06:39 PM
tuck1crx's Avatar
idk no1 has asked this but what fuel r u running? and what was it tuned on?
i should have elaborated.. if the answer to both of the above questions is 93 then bump up fuel pressure until your at ~13.5 WOT. from what you have told us, you should sit around the same AFR at part throttle depending on your injectors.
that will b 100% safe if what u have told us is accurate. might not be the best fuel economy but it will b safe.
last but definitely not least, Get a real tune.
EFI101, Advanced, CROME and Neptune dealer.
Old Apr 9, 2012 | 06:45 PM
v8killaz's Avatar
for partial to and cruising 15 should be fine if the car runs fine. for wot you do not want it at 15. im doing 17:1 at partial throttle with no ill effects
Old Apr 9, 2012 | 07:01 PM
Bendito's Avatar
I run 93. It was tuned on Hondata S300 (On a P28).. Im actually selling it so if it's safe, thats good enough for me. I never get on it, as I just take it to work & back but I don't want to set someone up for failure when they buy it.
Old Apr 9, 2012 | 11:10 PM
If it's on an S300 you can easily tune it yourself. AFR tuning is easy if you aren't worried about making power.
Old Apr 10, 2012 | 04:11 AM
DDTECH's Avatar
You're in florida, contact John vega or Blake Barr for tuning,
That AFR is perfectly find for cruising / idling.. @ wot you will want anywhere between 12.8-13.4 depending on what the setup will like.
Old Apr 10, 2012 | 05:30 AM
Bendito's Avatar
I'll pass on the info to potential buyers to bump up the fuel pressure a bit, chances are they're gonna drive it a lot harder than I do.
Old Apr 10, 2012 | 06:56 AM
Bix VT's Avatar
A quick tune is a much better solution, and you can probably make the adjustments yourself. And trust me, when they get in and drive it when it's around 13:1, you will sell it MUCH faster for a higher price, just because people will get that "speed smile" going.
Old Apr 10, 2012 | 07:40 AM
You've got an S300. Tuning with fuel pressure is terrible advice when you've got control over the entire damn fuel map...
