Reuse or Replace B18C1 Main Bolts?
Old May 8, 2023 | 10:25 PM
KilowattBandit's Avatar
5 Year Member
Default Reuse or Replace B18C1 Main Bolts?
I'm currently gathering the parts needed for rebuilding my GSR motor before sending it out to a shop, and I was just wondering if it would be worth it to drop $100 on new OEM main bolts? I have heard that you could reuse the original bolts as long as they haven't stretched, but would it be beneficial to replace them regardless? I have not been able to check if they have stretched.
Old May 9, 2023 | 06:20 AM
Chance EG's Avatar
Default Re: Reuse or Replace B18C1 Main Bolts?
Unless your current main bolts are fairly new/low mileage, I would get new ones.
Old May 10, 2023 | 11:11 AM
spAdam's Avatar
Loved
Community Favorite
If it's a stock/mostly stock/mild NA build that hasn't already been torn apart several times, you're very likely just fine. If you do decide to replace, an ARP main stud kit is only $110 - only downside being you'll need to check and possibly line hone with the studs.
Self edit: just use OEM and skip the headaches lol
Old May 10, 2023 | 11:19 AM
5 Year Member
Although this is the first time my B18C1 had ever been pulled apart, it's getting forged internals for a mild boost application. The problem with ARP main studs (from what I've read) is the difference in torque spec warrants the need for a line bore, which is something I wish to avoid due to cost and it being pretty overkill/unnecessary.
Edit - I happened to respond right after your edit LOL. Yes it seems OEM is the way to go.
Old May 10, 2023 | 01:08 PM
Chance EG's Avatar
Yeah align boring the main caps is mandatory when going with the ARP's increased torque spec. Recently did this to my B16 as I was getting a 3 point girdle installed in addition to the main bolts.
I'm planning on revving to 9K though and will be at ~350whp so figured it'd be good insurance.
92civiceg9gsr
13
Aug 5, 2012 03:07 PM
91tegraRS
Apr 12, 2010 08:19 AM
MeathooK
Jul 6, 2008 05:51 PM
85mm LS VTEC
May 19, 2004 07:57 PM
