Piston to wall tolerance and cross hatch longevity
Old Oct 16, 2024 | 05:20 AM
blackeg's Avatar
Default Piston to wall tolerance and cross hatch longevity
Getting curious here, how much does running a bigger ptw like say .004 with forged pistons and up cut down on the life of the motor and cross hatch wear. I'm thinking about doing another build but trying to daily it a lot on my 60 mile commute
Old Oct 16, 2024 | 11:54 AM
theYBLEGAL's Avatar
Loved
Default Re: Piston to wall tolerance and cross hatch longevity
From what i've seen, going too tight is what eats the skirts. Going a little loose you should be OK. I would (I do) just make sure it's warmed up a little more than I would a car with cast pistons before driving.
Old Jan 12, 2025 | 10:20 AM
NoMOACVWs's Avatar
Ever ponder asking the piston's OEM what his recommended clearances are?
Old Jan 12, 2025 | 09:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
There is a "Goldilocks" effect here... too tight, and yes, you can scuff the skirts. Too loose, and the piston rock is too high, and this will also damage the skirts. Right down the middle of these two is just right.
IB Cristina
Newsletter Archive
Jul 10, 2015 11:07 AM
atlplayer4life90
Nov 15, 2008 08:29 AM
X2BOARD
Jun 4, 2002 09:48 AM
