Piston ring availability for Arias Pistons
Old May 30, 2017 | 08:23 AM
JJDub's Avatar
Default Piston ring availability for Arias Pistons
My 76mm Low compression Arias piston rings are gone. Arias website nor ebay do not sell the Arias piston rings with part# 1012282992 alone, but with the pistons. Is there any compatible piston rings out there I can use to replace those worn rings? Compression ratio for those rings are 9.1:1, not sure if that is relevant.
Old May 30, 2017 | 03:06 PM
motoxxxman's Avatar
Default Re: Piston ring availability for Arias Pistons
contact arias directly. they'll sell you just the wring set. or you can try raceeng.com
Old May 31, 2017 | 07:30 AM
Pro-SeriesFab's Avatar
Why do you want their re-branded rings?
You just need to know the width and bore size and buy them from anyone else.
ziurek filmus
Apr 16, 2017 10:17 PM
hondachris1994
Dec 29, 2008 07:59 AM
siis2fast
Jun 7, 2005 03:52 AM
swlabhot
May 13, 2004 01:38 PM
