Piston clearance
Old Mar 20, 2018 | 06:02 PM
Danial Gooch's Avatar
Default Piston clearance
I have an 81.5mm head gasket and am going to have my block bored out, would i be able to keep my stock pistons and slap new rings in them or will i NEED new pistons if there not NEEDED what are the ups an downs of keeping my stock pistons
Old Mar 20, 2018 | 08:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Piston clearance
If you bore the block, the stock pistons will no longer fit correctly. You must bore a block for the pistons that you intend to use... to get the proper skirt to wall clearance.
Old Mar 20, 2018 | 08:40 PM
I thought so, any suggestions on pistons? Looking for around 350hp on 8ish psi
slammedef06
Apr 8, 2013 09:16 PM
Bgesy
Aug 24, 2006 04:28 AM
gaskleppie
Jan 4, 2004 11:39 AM
gtcali
Jun 14, 2002 03:49 AM
MisterB
Jan 15, 2002 11:26 AM
