No block notching
Old May 13, 2016 | 11:47 AM
Ronnie Cason's Avatar
Default No block notching
Does anyone know if there is any aftermarket connecting rod that I don't have to notch the block to use as I'm planning on doing this while the engine is still in the car and the crank still in the bottom end. And I already talked to Brian Crower and they are no longer making the bushings so that I could use ls rods with d-series slugs
Thanks in advance
Old May 15, 2016 | 12:12 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: No block notching
I am not aware of any aftermarket rod worth owning that doesn't require the notching of a "D" series block. Even the LS rod requires block modification...
Prepare to pull the block from the car... and do it right the first time.
LiLJisBooSTin89
Jul 8, 2014 07:32 PM
slowassBubble
Jul 1, 2011 04:57 PM
TomTread
Apr 21, 2008 01:35 PM
Si Integra
Jun 17, 2005 03:25 PM
turbosi03
May 24, 2004 09:01 AM
