Main bearing wear after 400 miles.
Old Apr 17, 2020 | 11:58 PM
MotorMouth93's Avatar
10 Year Member
Default Main bearing wear after 400 miles.
Any ideas on what's going on with these bearings? It's also worth mentioning that the shop that converted the rods from press fit to floating wrist pins royally fucked up the pin clearance, so the bushings were getting chewed up, as seen in this photo.
Bearing clearances: 0.0015-0.0017" (spec is 0.0009-0.0019" and I was shooting for the high side of the middle of this range)
Crank journal OOR: 0.0001" or less
Crank runout: 0.0003" (spec is < 0.0006")
Main bore OOR: 0.0002"
If I measure the worn looking spots with a ball end micrometer, I generally get measurements within 0.0001" of the non-worn spots so its very minimal wear. In some (but not all) cases the worn spots are actually thicker, indicating that its just a high spot on the surface of the bearing.
Any ideas? Perhaps brass shavings from the rod pin bushings making it through the oil filter and damaging the bearings? Main bore alignment off a bit? I'm kind of leaning towards main bore issues, when I tore it down the first time the main bearings showed fairly significant wear, and I suspect that this motor was overheated in the past and the guy who did the block machining mentioned that it had a low spot in the middle of the decks.
Old Apr 18, 2020 | 07:57 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Main bearing wear after 400 miles.
Photo's won't load, says errors. You can upload them directly to your post with the image button. This alleviates problems with third party hosting sites.
Old Apr 18, 2020 | 11:18 AM
10 Year Member
Okay I added them as attachments, the photo button wasn't working in my browser for reasons.
Old Apr 29, 2020 | 06:18 PM
DaX's Avatar
DaX
Loved
Community Favorite
Did you look to make sure nothing was between the bearing and the block? You may be right - the mains may need an align bore. Have a machine shop check it out.
Old Apr 30, 2020 | 02:49 AM
NVturbo's Avatar
O.G. triple O.G.
looks like the wrist pin "alteration" is the culprit for the damage. Why the change when it works fine??
Old May 3, 2020 | 11:47 AM
10 Year Member
Benson is going to clip the caps and line hone the block for me for good measure.
As for the reasoning behind getting new rods, at this point buying a 3rd set of OEM rods and having them machined is about the same price as just buying better aftermarket rods.
n/a_kong
Jul 2, 2010 06:52 AM
dj-t
Jul 2, 2009 08:48 AM
sixtodc4
Jan 20, 2008 09:33 AM
v4lu3s
Jul 26, 2004 11:25 AM
