Impact gun on head bolts?
Subscribe
Oct 25, 2001 | 12:00 AM
Head bolts are so hard to get loose... but something about using an impact gun seems like a bad idea. Afraid I will snap something off
Dustin
Oct 25, 2001 | 12:53 AM
Re: Impact gun on head bolts? (dustin)
just use a half of the bar for your jack as a breaker
Oct 25, 2001 | 12:56 AM
Re: Impact gun on head bolts? (Slow_ass_4dr)
That is what I currently do... and it sucks
Oct 25, 2001 | 01:20 AM
come on dont be a ***** :D, i took off like 1/2 mine the other day .....haha it was a struggle. i was pretty exhausted from just like 5 of them.
[Modified by immortal, 2:21 AM 10/25/2001]
Oct 25, 2001 | 07:00 AM
Re: Impact gun on head bolts? (immortal)
HA HA HA...........lol breakerbar, OR use a small hammer and a socket. Put pressure against the bolt and tap frimly a couple of times, until you feel it move. I use this method often on stuborn bolts. Saves knuckles from being busted.
[Modified by Speed PHreak, 4:02 PM 10/25/2001]
Oct 25, 2001 | 07:35 AM
Re: Impact gun on head bolts? (Speed PHreak)
according to the manual..
you're supposed to go 1/3 turn at a time...
if you use an impact... i think you'll spin them off... and run the risk of warping the head.... correct me if i'm wrong...
Oct 25, 2001 | 08:03 AM
Re: Impact gun on head bolts? (TurboT)
I only use an impact when the motor is cold, and I go in reverse order of proper install. Otherwise those fockers are tough! I've got a drawer of 3/8 14mm sockets that are broken from doing it, but I've never broken a head bolt.
Oct 25, 2001 | 08:09 AM
Re: Impact gun on head bolts? (VaporTrail)
Haha, yeah I broke a 14mm socket just the other day on a head bolt. Cracked it straight down.
Dustin
Oct 25, 2001 | 08:26 AM
Uhhh, are you guys using standard sockets with an impact driver(air gun right?). There are 2 types of impact drivers, the pneumatic type like I suppose you're using and the "manual" type you hit with a hammer. You should be using impact sockets with either one, they're black colored and way stronger. I've never broken a socket before.......The manual type would better for breaking lose those head bolts b/c you can hit the thing as hard as you can and it will only spin the bolt about an 1/8 of a turn
looks like this
Oct 25, 2001 | 09:06 AM
Have to use standard thinwall sockets because impact sockets don't fit into head bolt recess. At least mine don't. That's what craftsman lifetime warantee is for.
Oct 25, 2001 | 09:44 AM
Re: Impact gun on head bolts? (dbman96)
I'm all about beating things w/ a big *** mallet.
Oct 25, 2001 | 09:46 AM
Re: Impact gun on head bolts? (DragIIcivic)
LOL
Oct 25, 2001 | 09:58 AM
Heh, broken 3 Craftsman 14mm sockets, 1 on the head, the other 2 on the rear suspension, 1 of which litterally split into 2 peices, the other 2 sockets just cracked right down the middle.
[Modified by VTC_CiViC, 2:00 PM 10/25/2001]
Oct 25, 2001 | 10:03 AM
use a big torque wrench, set it at 5lbs higher than tightening pressure and work slowly, 1/10th of a turn each bolt, 15lbs more if you used threadlock, you run the risk of warpage and bolt strecth if you go crazy with a johnson bar
Oct 25, 2001 | 11:52 AM
Re: Impact gun on head bolts? (rtype11)
What are those things torqed to anyways?
I loosened those up on my friends gsr with a 1/2 inch driver and I would literally have to take a 5 minute brake for every two nuts that I loosened.
Boy I'm weak
Oct 25, 2001 | 02:08 PM
Re: Impact gun on head bolts? (newgsr)
Pussies Just use a big breaker bar you can buy at Autozone for like 25$... VERY good investment, and if you're steady with it and not jerky, then the bolt come off hella easy...
Oct 25, 2001 | 02:13 PM
use a breaker bar with a pipe over it as a handle, much easier on the hands.
I use impact sockets on the impact gun... But I use (and crack) regular sockets with just the breaker bar
Dustin
Oct 25, 2001 | 03:26 PM
cause your so damn strong dustin
lol
[Modified by KAMiN, 12:26 AM 10/26/2001]
Oct 25, 2001 | 03:44 PM
Re: Impact gun on head bolts? (KAMiN)
Broken Craftsman sockets are a good way to get new clean ones
Oct 25, 2001 | 05:01 PM
Hah, yeah I am super strong. You seen my pic? I look like I am 12 I used a 1/2" breaker bar + jack handle and cracked the freakin 14mm socket
Dustin
Oct 25, 2001 | 08:57 PM
use an impact socket (if ur breaking the regular sockets) or go buy a snap-on... i havent cracked any snap-on sockets from the headstuds yet and iv taken of a lot of heads... and then just use a breaker bar with about 1/3 to 1/2 turn increments (oh... and dont be a bitch about... like some of the pansy asses here! jk)
Oct 25, 2001 | 10:37 PM
Re: Impact gun on head bolts? (ek9t)
I've broken them ALL. Strap on, S&K, Mac, Crapsmen, you name it, I've split them (all 14mm's by the way) EXCEPT FOR some small cheap company called Premier. These things I can't find for myself, but my friend who helps me at my shop got them as a gift and he hasn't broken one in 3 years. He said the whole set cost him like 40 bucks or somethin.
Oct 25, 2001 | 10:43 PM
jeez wtf are the head studs torqued at?
Oct 26, 2001 | 05:15 AM
this is nuts, why do you guys have all these problems with tight 14mm, the only time we cant get a stud off is if the head is warped. - you do use torque wrenches for the head studs right, if you dont your arp's dont do their job right, - torque specs are right on the install instructions.
