Crankshaft Durability after Polishing
Old May 5, 2020 | 08:01 AM
310BHPB16's Avatar
Icon2 Crankshaft Durability after Polishing
Hello
I Spun bearing number 3 on a Euro ep3 K20a2 (Type R ) motor
I may be able to get away with just polishing it
I have heard you cannot regrind these cranks as they have a hardened Nitride layer and in a short space of time the big end bearings will get worn out again as a result
my question is
1.how long can I expect the bearings to last if I just fit oversized bearings
2.Do people usually get the Journals Hardened or is this something that is not necessary?
3. what is the biggest size oversized bearings I can use 0.5mm?
any other advice or input
would be appreciated
Old May 5, 2020 | 12:00 PM
starchland's Avatar
Default Re: Crankshaft Durability after Polishing
How bad is it out of round? Pictures
Old May 5, 2020 | 08:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I personally do not recommend cutting down a Honda crankshaft... but if you must, cut it the necessary amount so that you can use over-sized bearings. You will need to have it flash hardened after cutting or it will fail within 500 miles. Few can perform this process, so you may have to search a bit.
Old May 7, 2020 | 06:09 AM
kutlee's Avatar
You need to find out why it spun in the first place. if you can't find the reason, you will spin it again. I am currently running highest oversize on rods and second oversize on mains. this is a D series Y crank. It is still fine. i think 3rd and last oversize is .75 mm. I was having a slightly bent crank. so i put that on machine and took .5 off all mains to make it straight. So make sure why it spun. else that thing will start eating bearings.
D.Dappa
Jul 16, 2007 01:57 PM
aznwash3wboi
Oct 3, 2005 09:57 PM
itr1244
May 19, 2005 07:40 PM
db2integra
Sep 20, 2004 08:25 PM
tgreaves
Jan 22, 2004 05:52 PM
