B20v help with some hoses
Old Nov 26, 2022 | 09:26 AM
Team Loyalty's Avatar
5 Year Member
Default B20v help with some hoses
I just finish my fully build b20v and I block off some hoses spot and and one metal hose pole I don’t know where it goes I block off four spot and I wanted to know if I did them rite or wrong Thanxk for the help
This one I block off
this one I block off
This one i block off
this one I don’t where a hose goes to or do I need to block it off to
Old Nov 28, 2022 | 03:13 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: B20v help with some hoses
Pic 1 is a small coolant line that would normally go to the IACV, FITV, or throttle body. You may have deleted these.
Pic 2 is for your charcoal purge canister. I'm guessing you deleted this also.
Pic 3 is one of the coolant ports on the throttle body.
Pic 4 I'm not 100% sure on, but is probably the vent line from your fuel tank that went to the charcoal canister.
If you're not in a cold climate, deleting the coolant lines to the IACV, FITV, and throttle body won't hurt anything, except you may experience a slightly longer high-idle on initial warmup in the winter.
If you deleted your emission control system's charcoal canister, capping the line on the throttle body is fine. You should leave the fuel tank vent line open (not capped) though, so the fuel tank can vent and not build pressure.
Old Nov 28, 2022 | 03:25 AM
5 Year Member
Thankx so much for this information you a life saver man I’m ready to start her up but I didn’t want
Old Nov 28, 2022 | 03:28 AM
5 Year Member
What about this hose I block off look like a coolant hose
Old Nov 28, 2022 | 08:43 AM
DaX's Avatar
DaX
Loved
Community Favorite
Point out which specific hose you're talking about in that last pic.
Old Nov 28, 2022 | 10:19 AM
5 Year Member
This the one coolant hole
I mark it in black
Old Nov 28, 2022 | 12:41 PM
DaX's Avatar
DaX
Loved
Community Favorite
OK, looking back through your pictures it looks like you have the thermostat bypass hose and the heater core hoses mixed up.
The red U-shaped hose should come off the intake manifold by runner #4 and connect to one of the 5/8" nipples on the back side of the thermostat housing. To me it looks like you are going from the intake manifold to the heater core, instead. If so, this is wrong.
For the heater core, one hose should come from the head, underneath the distributor and run to the water valve mounted on the firewall. The other hose for the heater core should come from the other 5/8" nipple on the back side of the thermostat housing.
fastboy559
Nov 3, 2007 06:00 PM
CO_CReX
Apr 29, 2007 06:44 PM
4dr_allmotor
Nov 25, 2005 03:21 PM
jspeedy
Mar 18, 2004 06:49 PM
