B18c1 Brian crower valve spring install question
Old Aug 30, 2015 | 12:50 AM
H22egguy's Avatar
Default B18c1 Brian crower valve spring install question
I have a 95 gsr head installing the Brian crower BC0010 set of dual valve springs and titanium retainers kit. I know the factory's go with the right coils down toward the seat the BC's don't seem to have a tighter coiled end do you just put them in either way? I've searched and no one seems to have an opinion. Any help appreciated guys.
Old Aug 30, 2015 | 03:17 AM
Runnerdown's Avatar
Default Re: B18c1 Brian crower valve spring install question
What did Brian crower say when you called them?
I don't recall ever seeing a orientation for spring install on these motors.
Old Aug 30, 2015 | 03:36 AM
H22egguy's Avatar
I couldn't get anyone on the phone I suppose since it's a weekend. I emailed them yesterday also no reply probably the same reason it being Saturday. But I've actually measured them in and mm and seems to be the same on both the big spring and the smaller spring so I've just been installing them however i pick them up. They sit on the seats strange until you start compressing them because they're so much stiffer but once you compress them the keeper and retainers seem to flush up either way. So I'm thinking it doesn't matter
Old Sep 14, 2015 | 03:46 PM
saefifty's Avatar
The coils that are closer together go at the bottom close to the head.
Old Sep 16, 2015 | 12:28 PM
m4xwellmurd3r's Avatar
2 weeks after the last post and you didn't bother reading his post. Op says they don't have a tighter coiled end. Looking on their site, they look fully linear.
Old Sep 21, 2015 | 11:37 AM
saefifty's Avatar
You are right I read his post to quickly...As for the time lapse Im not sure why that matters ..An answer is an answer if it is right and helps.
Golding.racing
Dec 12, 2011 11:24 AM
SomeDude56
Dec 18, 2005 08:02 AM
jrcrx
May 30, 2002 06:46 PM
