B16a Stripped Valve Cover Bolt Threads
Old Aug 9, 2021 | 07:16 PM
LamGK's Avatar
Default B16a Stripped Valve Cover Bolt Threads
Hello, I'm creating this post hoping someone can point me in the right direction. I was replacing the valve cover gasket and hardware on my 95 del sol with a b16a. One of the studs had broken off so I ordered a Skunk2 valve cover hardware kit. Upon installing, the instructions said to torque the studs to 20ft lbs. I threaded all of them in by hand until they needed to be torqued. Long story short, one of the middle studs stripped the threads in the head.
After putting the valve cover back on, the stripped stud still seems to hold the valve cover in place. Should I even bother with a helicoil? If so, how would I go about doing so? Any help is appreciated!
Old Aug 10, 2021 | 08:21 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: B16a Stripped Valve Cover Bolt Threads
I would do a thread repair (I prefer Time-Sert) if it were mine. Use tape and painter's plastic to mask off everything but the hole - this will keep the chips from falling into your engine. Then, simply follow the instructions for the thread repair kit. Use a vacuum followed by compressed air to remove drilling/tapping chips. Make sure you drill straight.
Old May 17, 2022 | 06:34 PM
crajnai's Avatar
I got the exact same sitch on my 2003 civic. Stripped out the rear left bolt hole. I have the heli-coil kit. Was your fix successful?
any other advice appreciated.
liljohn850
Jun 5, 2009 04:23 PM
catfishracer4748
Oct 20, 2008 04:06 PM
ITR32
Jul 27, 2007 06:09 AM
RickyBizee
12
Mar 24, 2007 11:48 AM
JDM_lover03
10
Oct 19, 2004 07:06 PM
