Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Engine Machining & Assembly (https://honda-tech.com/forums/engine-machining-assembly-164/)
-   -   800hp build thread (https://honda-tech.com/forums/engine-machining-assembly-164/800hp-build-thread-3381499/)
Boostedmomo May 25, 2025 04:28 PM
800hp build thread
Just wanted to share my build, my goal is 800hp track/ street car. it will be turned down when i drive it on the street.
Block
-darton sleeved and O-ringed gsr block
-weisco 84mm pistons with upgraded wrist pins
- mainly turbo tuff rods with upgraded 625 bolts
- 4 piston oil pump
- acl bearings
-morso oil pan
- gsr water pump
- gsr crank
- arp L19 head studs
Head
- b16 head
- port and polished
- Skunk 2 pro xp 93lbs springs
- Skunk 2 pro series retainers
- ferrea comp valves
- skunk 2 pro 1 cams
- ferrea valve lock keepers
turbo kit
-BWR top mount turbo manifold
-44mm tial wastegate
-3 inch intercooler pipping
-Speedfactory 800hp backdoor intercooler
-precision 62/66 but was sent out to boostlab and was made into a 67/67
Fuel
- dual walbro 525 fuel pumps in tank
- 8an steel braided feed
-6an braided return
-aeromotive fuel filter
-aem fuel rail
-aeromotive fuel pressure regulator
-bosch 2200cc injectors
-car will be on pump e85
Transmission
- type R tranny
-freshy rebuilt with carbon syncros
-m factory lsd
-action twindisk clutch
(planning to go ppg)
engine management
-fuel tech 550
-fueltech nano pro
-t1 trigger kit
-coil on plug harness
miscellaneous
-edellbroke intake
-70mm throttle body
-speedfactory tucked radiator
-xs battery
-3 piece drag front end
-vms rims
-235-60-15 hoosier street drags
https://cimg5.ibsrv.net/gimg/honda-t...914e1b449.jpeg
https://cimg7.ibsrv.net/gimg/honda-t...26545c32f.jpeg
https://cimg8.ibsrv.net/gimg/honda-t...e09f50c28.jpeg
There is still a lot of work i need to do to the chassis, i plan on getting a cage and a parachute as soon as its running. there is already a running swap in the car that i am taking out to put this swap in. ill try to remember to add pictures as i go. i plan to track the car and drive on the street every now and then
Current update 5/25/25
The bottom end is assembled and ready, next step is to pull the current motor out of the car and put the new one in.
