window weld motor mounts
for some reason i thought this was for a stay for car door windows.
ive seen this done before but have never done it, i just went with innovative solid mounts!
So have anyone done there Rear trailing arm bushing,with 3M Window weld? Info would be great on the way the car felt? good/bad?.. Or if you went with Poly fill, good and bad effects and what brand filler? Links pic's would also be great.
The trailing arm actually moves inwards and outwards, so filling the rear TA bushing is a bad idea. I did it before I knew any better and it made the car very tailhappy in an uncomfortable way - ie hitting a bump at high speeds made the tail of the car wiggle.
haha, so there goes that idea, what kind of replacement would you suggest for a 1995 4 door GSR? I only seem to fine Polyurethane I want something I can just pop in once I remove the old one
On Skunk2's website theres a video tip, showing Dr.Charles filling a mount with "Duramix 4040" . But the editor of the video accidentally spelled it "DuraMAX 40/40". It says the cure time is 1hr, and worktime is 15min, and easily sandable. Just incase anyone ever searches for it, hope this helps.
I've used two different kinds. At homedepot in the paint section they have "PL" polyeurathane blah blah in a black and yellow caulking tube. This smells so bad like chocolate it'll make you hungry. The times I've used this the mounts are stiffer, but no bad vibrations from the interior ect...
hey is this what you used from home depo? I think its like brown inside. Was it rubbery or like rock hard when hardened?
hey guys check this one out. Its not my work but something still worth checking out
http://www.superhonda.com/forum/f94/...mounts-204274/
www.mcmaster.com p/n 8644K18 looks like its 33 bucks but you can choose what stiffness you want from 60 to 94 not back if you ask me
Doesn't energy suspension make an insert for the stock mounts? Not sure how stiff or how good they are. Just another idea. Maybe others can post what they know about it.
filled my stock mounts in my 1994 integra gsr. Got rid of alot of wheel hop and car launches alot more solid. There is a little vibration now, but it was worth the money. 13 dollars for a tube.
