What's your alignment setup for drag?
Old May 6, 2009 | 07:07 AM
JDMH22Prelude's Avatar
Default What's your alignment setup for drag?
I've got a 95 coupe, with the skunk coilover setup. 451hp turbo setup with MT 24.5 slicks. I zeroed it on the alignment rack trying to get the steering wheel straight because it was cocked. Car is pulling left in full boost to the point where it got squirrely at the track in first and second. I know I should toe it in a little so that it straightens out while under power. But how far in are you setting the toe? Is there anything else I should look into?
Thanks for any help or suggestions anyone has!
Old May 6, 2009 | 07:36 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What's your alignment setup for drag?
i aligned the car with stock toe settings and my fat *** in the drivers seat, and cranked the traction barrs to most positive caster i could get. so far so good.
Old May 6, 2009 | 08:14 AM
SovXietday's Avatar
That could be a lot of things, not just the alignment.
Are you sure you had equal psi in both of the front slicks? If one of them was lower than the other it would cause the same thing.
When you were on the alignment rack, were you able to check the dimensions of the chassis? If not, do you know of any possible frame damage that the car may have?
Caliper not letting go fully on one side?
Lots and lots of reasons for a car to pull, I'm just giving you ideas.
Edit: For the record, I'm zeroed out up front with as much caster as I could get from the traction bars and my car doesn't pull left or right.
Old May 6, 2009 | 08:21 AM
Not a caliper as far as I can tell, I haven't really checked the frame that much. Tire PSI was right before the run but off by a pound when I got back in the lanes.?
I don't have traction bars. But if I were to go that route should I be weary of certain brands? Thanks
Old May 7, 2009 | 07:06 AM
bump for any more help
Old May 7, 2009 | 04:02 PM
ALL IMPORT's Avatar
was always wondering & will be doing some testing when the car comes back out after this build.
I always wonder if it would be smart to toe out the tires 1degree or so cause when your under load the front tires deff are pulling the car . so if they are at 0degree the tire might want to wiggle a little due to the tire sitting im a center position.. as to being out a little it will hold more firm when it pulls .
think of a loose bike tire it wabbles back & forth . if it was angled enough it wouldent wobble but hold a steady position. same for a tire if its being pulled straight.
maybe im crazy but it might affect the car somewhat
Old May 8, 2009 | 06:16 AM
Well, I upgraded the brakes yesterday to hawk pads with brembo slotted and stainless lines, and as I was reinstalling the pads, I noticed that I was having a hard time getting the inner left front pad into the hardware. I took the caliper bracket off and noticed that there was a lip on the guide (it was a replacement bracket) that was making it difficult to slide the pad in.. I'm wondering if that lip was preventing full release of the inner pad. I did I quick test drive and it seemed to be a little better, but I haven't driven it further than a mile or so.
I still may try to toe it in if I get time before the next trip to the track.
Anyone have advice on which traction bars to use or not use?
Old May 8, 2009 | 06:22 AM
Kelvin Racing's Avatar
SpFab traction bars on here work great for me. Especially for the price. If not worried about money go ahead and buy the new Full race traction bars with the motor mount on them or w/e.
Old May 8, 2009 | 06:38 AM
Antilag's Avatar
I caster it as forward as i can go, but i even them out, i toe in 1/8 for bushing flex, and neg camber 1.5 on each side. When you launch the wheels wanna pull back. And the car lifts. So that kinda straightens the wheels and evens them out.
Old May 8, 2009 | 06:46 AM
redboost10's Avatar
ive read on here before that the tires want to move foward and in when we launch...
Old May 8, 2009 | 12:47 PM
noluckracing's Avatar
Are in totals or per side?
Old May 8, 2009 | 04:14 PM
ALL IMPORT's Avatar
i cant see them pulling back but deff can see it cambering in from lift but with the right suspension setup u shouldnt get hardly any lift
Old May 8, 2009 | 05:17 PM
HR-1320's Avatar
I don't know about the wheels want to pull back statement.
Old May 8, 2009 | 06:20 PM
OmegaDynamics's Avatar
Check tire runout?
Old May 8, 2009 | 07:06 PM
redboost10's Avatar
yeah i always thought these civic/integras pull the wheels forward when launching
Old May 8, 2009 | 07:19 PM
SPOOLINmatt's Avatar
they do most definitely.
Old May 8, 2009 | 07:21 PM
what do you mean by cambering in? When you launch and the front end lifts, your tires will go more towards the positive camber direction.
soloturbo
Nov 10, 2011 12:12 PM
Boostn B20
May 1, 2009 05:31 AM
allmotor2.1
Oct 20, 2007 08:12 PM
buzz1167
Suspension & Brakes
13
Aug 22, 2006 06:08 PM
