Ups and Downs running NOS..
Old Mar 3, 2004 | 05:15 AM
crxsirvtec's Avatar
Default Ups and Downs running NOS..
hey..
i would like to run a 40 to 50 DRY shot on my B16A1..
I have the CR up to 10.7:1
Stage 2 Cams.
Skunk2 Intake...
I want to know the ups and downs running this..
thanks
Old Mar 3, 2004 | 01:31 PM
crxsirvtec's Avatar
Default Re: Ups and Downs running NOS.. (crxsirvtec)
anything??
Old Mar 3, 2004 | 01:41 PM
alloutmotor's Avatar
not that many downs..except that the power is not there everytime..and that nitrous has a bad reputation...
Old Mar 3, 2004 | 01:58 PM
onelowchef's Avatar
Default Re: Ups and Downs running NOS.. (alloutmotor)
nitrous if great for the price, but it is kinda dangerous if your not careful. I sprayed a 50 shot for a while, but then one time my bottle heater relay broke and the bottle got alittle to hot and then this happen............
http://www.we-todd-did-racing....DE%3D
Old Mar 3, 2004 | 02:04 PM
crxsirvtec's Avatar
Default Re: Ups and Downs running NOS.. (onelowchef)
do you need a heater?
Old Mar 3, 2004 | 02:52 PM
onelowchef's Avatar
in the winter you need a bottle heater, but if its warm out you should be alright. Your bottle pressure should be around 900 to 1100. your bottle heater keeps it in that range.
Old Mar 3, 2004 | 02:56 PM
yeah u wanna keep the bottle pressure up....low bottle pressure is a no no
onelowchef's Avatar
Default Re: (alloutmotor)
and too high of bottle pressure is a no no, thats what happen to me.
Old Mar 3, 2004 | 02:59 PM
automatic_itr's Avatar
Default Re: (onelowchef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onelowchef &raquo;</TD></TR><TR><TD CLASS="quote">and too high of bottle pressure is a no no, thats what happen to me.</TD></TR></TABLE>
not smart
Old Mar 3, 2004 | 03:07 PM
RaceProfessor's Avatar
Let's forget about having to fill the jug all the time. Although we have a place here that does for 2.50 a pound.
Sam
Old Mar 3, 2004 | 03:45 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onelowchef &raquo;</TD></TR><TR><TD CLASS="quote">in the winter you need a bottle heater, but if its warm out you should be alright. Your bottle pressure should be around 900 to 1100. your bottle heater keeps it in that range.</TD></TR></TABLE>
down: things change with temperature/pressure.. makes nos kinda hard to tune and dangerous. Keep and eye on your sparkplugs and an ear on your engine...
but a 50 dry (or 55 zex) is not much to worry about if you do your homework - KEEP LOOKING AT THE PLUGS.
up: EASY power
Old Mar 3, 2004 | 07:41 PM
whatVTEC's Avatar
A little off topic, but I may sell my NOS Noszle kit if anyone is interested. This is the kit that has the nozzle that goes into the intake manifold and the injector goes on top( basically direct port w/o having to drill).
Old Mar 4, 2004 | 11:49 PM
n2ones's Avatar
Default Re: Ups and Downs running NOS.. (whatVTEC)
Nitrous is probably one of the safest forms of making hp. If you purchase a kit from any reliable nitrous manufacturer you can be guaranteed of the following:
1. They know the limits of the engine
2. The system comes with jetting that requires no tuning
3. You can easily install the system in a day and as easily remove it
4. You will not sacrifice drive-ability
If you read the instructions provided with the kit and use the recommended jetting you can be guaranteed trouble free performance for a very long time.
I would recommend a dry system for your application. A B16 is fuel injected and the induction system was not designed to flow fuel. Since fuel is an alien substance to the intake manifold it runs the possibility of puddling in the plenum causing uneven fuel distribution. A dry system injects nitrous in the plenum, fuel is added via the fuel injectors, a pressure safety switch monitors fuel pressure and prevents the solenoids from activating unless the adequate pressure is present.
A B16 can easily handle 50-60hp. You should always run your bottle pressure between 900-950. as the pressure in the bottle increases it's density decrease and anything over 1000psi is inconsistent and slightly unstable. most Pro Mods I work with run 900psi tune ups.
I would also recommend a bottle heater, a bottle's ambient pressure is 750psi and as you consume nitrous a bottle heater can help maintain a more consistent pressure.
If you have any questions feel free and e-mail me. I have over 8 years of experience with nitrous oxide injection. My teacher was Mike Thermos, maybe you've heard of him......
Old Mar 8, 2004 | 03:48 PM
jdmspec1122's Avatar
damn who ever was driving that car doesnt know how to drive period. its not cause the nitous is dangerous but the driver sucks thats whats dangerous. its like really really old people behind the wheel.
d15.hatch
Apr 4, 2006 03:29 PM
Layziebtnh055
Aug 8, 2005 12:47 PM
megotvtec
Apr 12, 2004 08:03 AM
92KillerBee
Jan 8, 2004 01:41 PM
