Trap speed of 104 mph
Old Jun 8, 2003 | 08:32 PM
TORQUE MONSTER's Avatar
Default Trap speed of 104 mph
wat should my et be with that trap speed..?/
thanks
Old Jun 8, 2003 | 09:20 PM
Allmotornonvtec's Avatar
From: Somewherestreetracing, Md, not a spelling bee
Default Re: Trap speed of 104 mph (TORQUE MONSTER)
Try this out (1320 divided by your MPH) that will give you your ET on perfect traction. It = a 12.73
Old Jun 8, 2003 | 10:01 PM
J2turbo21's Avatar
Default Re: Trap speed of 104 mph (Allmotornonvtec)
Thats a sweet calculation Im guessing thats on slicks to get perfect traction.
Old Jun 8, 2003 | 10:16 PM
Default Re: Trap speed of 104 mph (J2turbo21)
Yea that works with slicks best. I've tried it on a bunch of different cars and set ups and it seems to be right on point every single time no matter what the car runs. Turbo cars will be a little slower because of the traction ussues.
Old Jun 8, 2003 | 10:54 PM
J2turbo21's Avatar
Allmotornonvtec your right it does work,it says you should have ran a 12.33 and you ran a 12.4 with the 107mph trapspeed
Old Jun 8, 2003 | 11:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">Allmotornonvtec your right it does work,it says you should have ran a 12.33 and you ran a 12.4 with the 107mph trapspeed </TD></TR></TABLE>I can get much more out of the luanch then that. Now i just need to do some more fine tuning to reach my goal. - THANX
PS thats a little trick i learned a long time ago. It seems to work.
Old Jun 9, 2003 | 09:04 AM
Greyout's Avatar
I think that only works for faster cars...
I don't think I'll ever see anything, even AWD, trap 93 mph and run a 14.19
Old Jun 9, 2003 | 09:53 AM
slooogsr's Avatar
i think too many factors go into it for that calculation to work right......... i ran a 16.03 @ 73mph, only because i let off bout 3/4 the way down the track or more....... by that calculation it came out to be an 18 something.
Old Jun 9, 2003 | 11:25 AM
JDM97R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TORQUE MONSTER &raquo;</TD></TR><TR><TD CLASS="quote">wat should my et be with that trap speed..?/
thanks</TD></TR></TABLE> MY et is 13.2 at that trap speed with drag radial tyres with a 2.0 60'
Old Jun 9, 2003 | 12:12 PM
Default Re: Trap speed of 104 mph (JDM97R)
yeah i got a 13.48 with 2.1 60ft mark.. drag slicks.. but i hit my rev at 4th gear at the end. so I ended up at 104.1 mph.. So with some practice and good driving you think i can hit high 12's?
Old Jun 9, 2003 | 12:13 PM
dman man how did you get 1.6 60 ft mark?? wat tires and pressure?? and where do u launc at..?hook a brother up dog.
Old Jun 9, 2003 | 12:15 PM
SergEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97R &raquo;</TD></TR><TR><TD CLASS="quote"> MY et is 13.2 at that trap speed with drag radial tyres with a 2.0 60'</TD></TR></TABLE>
We are talking about real 1/4 drag strips.....an R with your mods should never see 104mph especially factoring your ET. Most likely the strip you went to used a radar/laser setup to give you a bolt-on R trapping 104....on stock cams
I say the 1320/ trap speed = ET is a good rough estimate of IF you had a perfect launch you could expect such and such ET
Factoring gearing/weight/hp/traction......its all a numbers game but its exact enough to set a realistic goal with a particular setup weight/hp/traction in mind. Plus it helps filter out the BS that some people post.
Old Jun 10, 2003 | 11:26 AM
CM-R's Avatar
Default Re: Trap speed of 104 mph (SergEK)
I hit 13.4 @ 106 mph at sac raceway and my little brother hit 13.6 at 106 mph...We need slicks badly no traction for $hit......The 1/4 mile calculation says we should hit 12.45 in the 1/4 mile....damn our times are way off...need some practice
Modified by CM-R at 1:03 PM 6/10/2003
Old Jun 10, 2003 | 11:35 AM
LSiTurbo's Avatar
Default Re: Trap speed of 104 mph (CM-R)
If Ricks calculations says so then that is the WAY IT IS!
Old Jun 10, 2003 | 08:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TORQUE MONSTER &raquo;</TD></TR><TR><TD CLASS="quote">dman man how did you get 1.6 60 ft mark?? wat tires and pressure?? and where do u launc at..?hook a brother up dog.</TD></TR></TABLE>M&H 22x9x13 @ 6.5psi leaving @ 6300 rpm on the 2step.The trick i leaned is to do a 2nd gear burn out and dont stop burning out to the car pulls out of the water. that should do the trick.
Old Jun 10, 2003 | 08:29 PM
ok so 6 psi and do a crazy burn out and launch at 6.3k alright i'll give tht **** a try
Old Jun 10, 2003 | 08:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TORQUE MONSTER &raquo;</TD></TR><TR><TD CLASS="quote">ok so 6 psi and do a crazy burn out and launch at 6.3k alright i'll give tht **** a try</TD></TR></TABLE>What tires,psi,rpm?
Old Jun 10, 2003 | 08:38 PM
i got MT slicks 22X15, i was running 15 psi tire pressure but i'll lower it.. and i was launching at 5k.
but i'll try wat you said
Old Jun 11, 2003 | 08:26 AM
LSiTurbo's Avatar
22x15 bont have enough side wall for most cars. 15psi is way to high. with those slicks i'd try like 7-9psi. it sould hook if it boogs just leave higher until it stops booging and it should do a 1.8 60" @ least.
Old Jun 16, 2003 | 08:41 PM
CM-R's Avatar
Default Re: Trap speed of 104 mph (LSiTurbo)
what tire pressure should i put 23x15 inch MH slicks at ? 10 psi or 12?
Old Jun 16, 2003 | 11:04 PM
ClubSiRacer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Allmotornonvtec &raquo;</TD></TR><TR><TD CLASS="quote">Try this out (1320 divided by your MPH) that will give you your ET on perfect traction. It = a 12.73</TD></TR></TABLE>
This doesnt make sence... My 12.3 @ 116 should have been an 11.3 accoding to this calculation!?
Old Jun 16, 2003 | 11:07 PM
tony1's Avatar
Default Re: Trap speed of 104 mph (ClubSiRacer)
I think that formula relies on average hp, not peak like the vortech makes. You know your car would be mid to low 11's with 350 turbocharged hp.
Old Jun 17, 2003 | 09:15 AM
DIRep972's Avatar
Smarter than you
Default Re: Trap speed of 104 mph (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I think that formula relies on average hp, not peak like the vortech makes. You know your car would be mid to low 11's with 350 turbocharged hp. </TD></TR></TABLE>
yeh, that calculator assumes you have some torque area to back up ur peak #'s lol.
Old Jun 29, 2003 | 05:30 PM
yo i got my 60' mark to 1.9 still need to work on the launch..
but this time I hit 12.6 at 106 mph
and then hit 12.9 at 107 mph..
wat should I be running if i can drive better?
thanks
Old Jul 4, 2003 | 08:41 AM
AussieK24's Avatar
If you can knock 1 tenth off your 60 it'll knock 2 tenths off your ET. You should be able to get 12.5's with practice.
