Re: Traction Bar Preload
j-bird20, it is sad how many products are sold that are simply designed wrong. And the truth is that the sphericals only greatly magnify the 100% incorrect design of those EF traction bars with two sets of heim joints. The LCAs were already rotating on launch with the OEM bushings but it was not obvious before when the car was on the rack. I won't sell EF spherical LCAs anymore to drag customers without asking what traction bars they are running. If you bought arms from me I don't mind refunding or selling them for you if they have never been used.
Chris |
10's with a 340?
Originally Posted by chrisb
(Post 48789481)
Chris |
Originally Posted by j-bird20
(Post 48789618)
I did not buy them directly from you and i would not want a refund either way. I am in the process of researching to find a solid heim joint for that or possibly call full-race and see if they can possibly get them. ORRR possibly make 2 new bars out of chromoly and so it just like the Innovative Bar.
http://www.rodendsupply.com/special-products.php |
Originally Posted by redboost10
(Post 48789531)
10's with a 340?
Most 26" tired cars envy my short track and I do it with traction bars.... 1.50, 4.0 and 6.0 on just about EVERY track that I've run on.... 24.5" 2400lbs with less then 800whp... If I could only figure out this traction thing and be apart of this "fastest" thing.. Who knows I may even win a race.... A man can dream:door: |
(Post 48789481)
Chris |
Originally Posted by 1FASTHF
(Post 48790354)
So does the spherical bearing make the rotation of the arm worse? I thought the spherical bearing would prevent that due to its strength and rigidity.
In the case of these two or more high profile companies selling EF "traction" bar setups, they are using two pairs of heim joints. That is wrong. Period. They should pull those products off the market. The legs of the traction bar are no longer rigidly tied to the LCA. The LCA can rotate forward while the legs of the traction bar articulate upwards. The problem has nothing whatsoever to do with my parts or any other company that sells sphericals for the EF front LCAs. It is an issue of bad "traction" bar design. If you take my or any other companies spherical LCAs and run stock radius rods and radius rod bearings or you use spherical LCAs and a proper traction bar setup that rigidly ties the traction bar legs to the LCA this issue does not exist. You just simply want the front and rear pivot points of the LCA to act in concert. Think of the UCA. It is simple right? The entire UCA should pivot together. It is triangulated. That is all you want with the front LCA. Now you want to open a can of worms, start talking about the rear of a DC/EG/DA/EF. That is a bad design as well but you can blame Honda for that. But unless you are road racing who cares. |
Thanks for clearing that up. The spherical bearings are my next upgrade but it looks like I have to do something about my bars now too.
(Post 48789407)
Put some spherical bearings in a EF lower control arm with a traction bar other than INNOVATIVE's and see wut happens. Its not something u would want to see after spending $500 bucks on a solid lower control arms. Ask me how i know. :) I only can speak for EF owners though.
I put sphericals in my EF front lca's, thought I was going to be doing some good for it. I was wrong. I have yet to completely finish my car and drive it, but I am now looking at trying to get a something more solid so I can cut down on that rotation that chrisb is talking about. These may work though..... http://www.rodendsupply.com/special-products.php |
are the ef chassis breaking ball joints when the LCA rotates ?
Originally Posted by dturbocivic
(Post 48793666)
(Post 48794084)
The ball-joints on my car are about 3 years old and they dont show any signs of breaking but this year is the first year i will be using the spherical bearings but i wont be letting those arms move like that. The rotation of the arms will be fixed before the car goes out.
I was just out in my garage looking at my car and doing a little research online to check out solid rod ends that I could possibly use. |
1 Attachment(s)
A little update. Had some time in the morning to think about this. I figured i would weld the original heims to keep them from swiveling and it seems like the problem is fixed. Put everything back on and the lower control arms doesn't move one bit. They are welded on both side.
Pretty solid stuff there J-bird.
Nice j-bird20. Before I saw the pics of your welded heims I talked to a friend about doing the same to mine. Let me know how that works out for you. I hope to have my car done by September and I am sure you will have yours all back up and running before me.
Jason your rough settings here when your talking about toe do you mean in inches?
As mentioned on a EF style dual joint traction bars aren't right, I've had end adjusters made to convert mine into a innovative style trailing arm.
Originally Posted by littlebluecrx
(Post 48781503)
What we used to run on or ek back in the day... we would put prothane bushings in them...
You guys can argue all you want ... getting bent out of shape when people are offering advice about caster is really being closed minded... Feel free to experiment and find out what works for your setup.. Some people said they did not like positive caster so they put things back fine... I can just say from years of running crx's eg's tegs, ek's etc on a small tire.. with cars that get sixties from 1.49 to 1.55 and 4.0 330's on 24.5's I can give an honest opinion on what works.. We use the traction bars to even out caster ... most of these cars will have un even caster, we normally pull the wheels forward, a lot of times we even them up in the fender so the wheels don’t rub " you know back in the days before 3 piece front ends" ... Normally a little bit of positive caster makes the car more stable , if you disagree there is something else wrong with your car or you have no feel for what’s going on under you. After castor is set we do camber then toe... normally run around 3-5 degree castor -.5 camber and a total toe out of around .20... rear we leave stock setting unless camber is real negative from lowering car… These are generic and specific cars might need changes, depending on how cars respond thru travel, bump steer etc... This is more for stock suspension pieces not aftermarket arms etc... Take it with a grain of salt... but dont say false like your opinion is the end all be all ... Theres more then one way to skin a cat ... |
