torque mounts
Old Apr 2, 2011 | 01:40 PM
rudebwoy's Avatar
Default torque mounts
is it necessary to use the lower torque mount when running solid motor mounts? my current build is shooting for 750-800 whp , I will be running solid mounts, I also have solid torque mounts but if I need then I will not install them.
let me know some experiences, opinion, facts.
Old Apr 2, 2011 | 07:03 PM
boosted_b16a2's Avatar
Default Re: torque mounts
from my experience the less that engine moves the better it makes it to shift.
Old Apr 2, 2011 | 08:26 PM
redboost10's Avatar
i removed them and the first thing that happened was the tacked on nut on the rear T bracket broke off so the motor had a bit of a "rock" to it and it was screwing up the gforce shifter. from the factory, that nut has three small tack welds. i would weld the whole way around the nut if you dont want to run the torque mounts.
Old Apr 3, 2011 | 10:54 AM
rudebwoy's Avatar
I guess I will use my torque mounts then, no need to remove them if it will cause problem. I guess thats why they are called torque mounts. thanks.
Old Apr 3, 2011 | 11:44 AM
dturbocivic's Avatar
i recomend keeping them, realisticly if they were removed you have 2 mounts on pretty much the centerline of the engine, and it will move on that axis. the torque mounts prevent this from happening.
Old Apr 3, 2011 | 04:04 PM
Zer0_SpeedWorks's Avatar
use it...i agree with them...personally im using avid tq mounts...
vinnyme50
13
Nov 30, 2023 05:38 PM
tyrel-gsrturbo
Aug 25, 2021 08:18 AM
B_Swapped93
Oct 28, 2013 06:22 AM
DaOnE51T
Aug 26, 2013 09:22 PM
Muckman
Jul 16, 2011 02:39 AM
