Which supertech valve spring?
Old Mar 2, 2019 | 10:29 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Which supertech valve spring?
So I reached out to a few people to try and get information but I've not had a lot of luck ... from what I understand super tech makes and B series 85 lb valve spring and a drag only valve spring I've heard that with the drag only valve spring there can be no street driving and it is strictly for the track is this true? My set will be around 800-900hp mainly tracked but with some weekend driving ... any help will be appreciated thanks
Old Mar 3, 2019 | 09:28 AM
motoxxxman's Avatar
Default Re: Which supertech valve spring?
which head is being used? What cams? We need a lot more info
Old Mar 4, 2019 | 05:51 AM
Throwdown's Avatar
B16 head ctr cams... what info you got for me?
Old Mar 5, 2019 | 07:48 AM
hondaracing84's Avatar
From what I understand, the reason the track springs (100lbs) are track only is because the durability is limited to so many hours of use. I can tell you from experience that springs have a lifespan. Not just in the fact that they lose pressure, but eventually will break. More so with higher lift cams. Also, I think they aren't meant for a lot of low idle.
I made 800hp on the 85lbs springs. My opinion is you would be fine with those.
You might want to call supertech and get more advise on those springs and how many hours of use.
Old Mar 5, 2019 | 08:41 AM
Throwdown's Avatar
Thanks for your reply bro, I have spoke to supertech and they had me send a email to their engineering department.. I'm still waiting for a reply but when I get one I will post the info I receive for future reference
carlos8
Nov 26, 2015 07:16 PM
avotegra
Dec 3, 2008 12:35 PM
Grand
Aug 31, 2005 01:36 PM
jrcrx
May 30, 2002 06:46 PM
chasrex
Apr 13, 2002 01:33 PM
