Straight Meth
Old Jun 13, 2009 | 06:51 AM
boostedb20z's Avatar
Default Straight Meth
has everyone ran just straight meth ive heard alot about the meth injection but never heard anyone running straight met.
Old Jun 13, 2009 | 07:15 AM
96 GSR-T's Avatar
Default Re: Straight Meth
For a race car only you can use it, you need 100% extra fuel capacity..... if you needed 1000cc Injectors for your setup you will need 2000cc Injectors and double the pumps, everything has to be Methanol Compatible, and you have to drain it every day and you should change your oil after every event.
Old Jun 13, 2009 | 08:44 AM
Garage 808 Hatch's Avatar
theres actually an additive for methanol, that prevents it from corroding the lines, fittings etc. I'll find out again on monday what its called and report back. My machinist runs drag boats and uses this stuff. He called BS on it working that well, and the company rep told him to try it. Left the tank and lines full of methanol for the entire winter, tore it down in the spring, and everything was great. But ya, i'll get the name of it again monday
Old Jun 13, 2009 | 11:18 AM
HR-1320's Avatar
VP makes top end lube. I use it and leave my stuff sit in between races and get away with it. But all winter is pushing it. Everything people put on there cars can pretty much hold up to alcohol. But the orings on injectors or boss fittings get screwed up. You need viton orings.
Old Jun 14, 2009 | 10:43 AM
ALL IMPORT's Avatar
deff gotta change the oil every event unless u like milk in your oil. aint no aditive gunna prevent that. & u do use an additive for meth its to lube the fuel. cause its a dry fuel.
supposed to drain the fuel first. then add reg gas. change the oil. then run the car with new oil & fuel through the system ( lubricate seals ect.)
but to answer your question is yes u can spray straight meth trough a
"meth injection kit".why people ad water as well i dont know seems stupid to me, cause u cant burn water at least not in our motors.
get the advantage of straight meth. not meth/water
Old Jun 14, 2009 | 12:17 PM
Garcia-Racing's Avatar
We have to change the oil every 3 passes. We boil the alcohol out in between rounds but it breaks down fast.
Old Jun 14, 2009 | 12:18 PM
sleeperaccord's Avatar
New User
race car only pal
Old Jun 14, 2009 | 12:19 PM
huh?
Old Jun 14, 2009 | 12:37 PM
ALL IMPORT's Avatar
in theory we should be changing it every pass, but none of want to spend the $$ on that.
what do u mean by boil it out? u guys are getting high tech, lol
Old Jun 14, 2009 | 03:21 PM
We run a hear in our oil tank. Boils the oil, alcohol evaporates. The oil lokks almost brand new after. Race car app. only.
Old Jun 14, 2009 | 03:46 PM
eg6-itb's Avatar
Icon3 Re: Straight Meth
GOOD INFO!
092eg6
Dec 14, 2009 10:02 AM
SlowEJ8
27
Apr 19, 2009 07:57 PM
EZ$$EF
Oct 8, 2008 06:39 AM
EG6 Love
Feb 28, 2008 07:47 PM
vtecdc2
Aug 5, 2002 10:56 PM
