split brakes
Old Jan 28, 2012 | 04:03 AM
94boostedhatch's Avatar
Icon2 split brakes
does anyone make a stainless braided line kit for front brakes wilwood booster delete to calipers and then a rear kit for cnc stage brake to rear calipers? if so can somone let me kno some pricing i will also need cutch line and master cylinder kit for that also
Old Jan 28, 2012 | 05:59 AM
KStuned's Avatar
Default Re: split brakes
Use hardline where you can. And any soft lines can be made at local hydraulic shops. Just measure your lengths and know what type of end you need crimped on (straight, 90, etc.) Brake lines commonly use -3an fittings. If it's banjo then it's measured in regular bolt sizes like 10mm.
Old Jan 28, 2012 | 06:02 AM
061000rr's Avatar
if you got the money chase bays has i real nice kit
Old Jan 28, 2012 | 06:19 AM
ill check out chase bays i really wanna do everything stainless braided to match fuel lines
Old Jan 28, 2012 | 06:26 AM
061000rr's Avatar
then i would go with them. top notch stuff there. also you may want to look into fcs fab. they do really nice clutch lines and brake lines. they may be able to make you custom lines for your car. and that would also be supporting the guys that i see support us
Old Jan 29, 2012 | 03:54 PM
i saw they have the clutch kit i want also the fuel cell and radiator hose kit
integrawow
Suspension & Brakes
Jun 15, 2010 01:27 AM
redboost10
Suspension & Brakes
Oct 30, 2008 08:55 AM
evans_art
Jun 20, 2007 12:46 PM
lo0nY
Oct 31, 2006 05:34 AM
showgunz
Apr 11, 2003 04:05 AM
