slick size?
Old Jan 1, 2009 | 02:38 PM
bertsb18hatch's Avatar
Default slick size?
i have a built ls on nitrous and it was dynoed at 283 to the wheels. im running 22x8x13 slicks right now, and my fastest 1/4 mile is 11.91 @ 113, spinning throught 1st and 2nd. im changing a few things and will be looking for over 300 to the wheels. will 23" slicks be ok for my setup, because i was said the 22" slicks are too small now.
Old Jan 1, 2009 | 02:47 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: slick size?
i think 23"s at your power level will be fine.
Old Jan 1, 2009 | 02:52 PM
b20vtek's Avatar
agreed
Old Jan 4, 2009 | 04:59 PM
ok thanks. i was trying to get a few opinions, because people were telling me the 22" slicks were fine. im running the b16 tranny and running out of 4th on the top end, thats why i wanted to go to 23" slicks.
Old Jan 4, 2009 | 05:36 PM
SlicksMH's Avatar
8/23-13, that would be the ones you need.
John
Mandhtires
Old Jan 5, 2009 | 08:07 AM
fukenricen's Avatar
you guys dont think a 24 would be just fine at that level i know with 270 AllMotor the key was 24.5's
Old Jan 5, 2009 | 11:32 AM
Mr. Badwrench
i guess that would depend on the gearing and how high he was reving the engine.
Old Jan 5, 2009 | 11:35 AM
JDM JEFFREY's Avatar
i would say 23's
Old Jan 5, 2009 | 11:37 AM
ExospeedAMcrx's Avatar
23s will work for that setup the best. There's alot of factors that determine what size you want to use. Not just the HP. Gearing, RPM shift point, etc. In this case, how much nitrous and when is it used. If you're on the bottle straight out of first gear, for sure the 22s will just be overpowered. You're going to need the 23s. The 24.5s may work as well, but then it has to have the gearing, and rpm to make it work.
Old Jan 5, 2009 | 12:54 PM
fukenricen's Avatar
i guess we need some more info in order to help a bit more
Old Jan 5, 2009 | 01:17 PM
the car is on 100hp shot, its a fully built non vtec b18a1, with stage 3 exospeed ls head. im pulling the car to about 8200, but in fourth going across the traps im at about 8500. and yes im spraying out the hole.
Old Jan 6, 2009 | 03:13 PM
so should i go with the 23's?
Old Jan 6, 2009 | 03:14 PM
SOHCinWA's Avatar
John
Mandhtires
I would probably listen to John since he deals with this day in and day out.
shortstopNE
Dec 28, 2008 05:48 PM
uptownspeedstar
Apr 14, 2008 04:08 PM
ek_slut
Jun 9, 2006 10:21 AM
b18c198
Jun 18, 2005 07:04 AM
BEEYOND
Jul 4, 2004 12:55 AM
