Scatter Shields?
Old May 8, 2006 | 11:08 AM
N20civicB18's Avatar
Default Scatter Shields?
I am debating between the GE or Mazworx bolt on scatter shield or the Exospeed blanket.... Will the blanket meet all the rules that the tracks will require or will I need to get a 1/4" thick scatter shield like the rule books say?
Old May 8, 2006 | 11:21 AM
ExospeedAMcrx's Avatar
Default Re: Scatter Shields? (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">I am debating between the GE or Mazworx bolt on scatter shield or the Exospeed blanket.... Will the blanket meet all the rules that the tracks will require or will I need to get a 1/4" thick scatter shield like the rule books say?</TD></TR></TABLE>
The transmission blanket is actually made by DEIST Safety. Its SFI approved and meets the NHRA requirements. It does fit the D16 and B-series transmissions. I havent tried it on an H-series yet, but I hear it does fit as well.
* Deist has us stocking the blankets so its ready to ship out when needed, through us. We can Next Day them if needed so just let us know *
We're also finalizing the design for the engine diaper, so it can fit MOST setups.
We have the template for regular equal length style manifold ready with a decent size turbo, but we're just waiting for a motor we're doing so we can mock up the one with a Top mount setup.
Personally I'd like to run a pan like the one Joe made, but for most street guys who just need to put it on a diaper for the race, we're trying to get this going so there wont be any issues with clearance and material getting too hot.
Old May 8, 2006 | 11:48 AM
Mikey3000's Avatar
GE's scattershield is garbage, don't get it. They say it installs in 15 mins, bullshit. I have to modify the expletive out of everything to make it fit.
Old May 8, 2006 | 01:03 PM
Default Re: Scatter Shields? (Mikey3000)
I havent personally put blankets or scattershields in cars in a while, but I would think anything under the hood like that would take a bit of time to install.
Old May 8, 2006 | 01:37 PM
boostfeen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">GE's scattershield is garbage, don't get it. They say it installs in 15 mins, bullshit. I have to modify the expletive out of everything to make it fit. </TD></TR></TABLE>
.. i use the GE scatter shield and i didn't have any problems with it. matter a fact it only took us 10 min. to bolt it up. So i don't know why you were having any problems.
Old May 8, 2006 | 01:45 PM
vtekthis's Avatar
Default Re: Scatter Shields? (boostfeen)
the deist is nice, and really makes it easy too
Old May 8, 2006 | 02:49 PM
efi2nr's Avatar
From: Home of the fastest Hondas in the 417 area since, 1997, usa
if you need it for a B series the Mazworx shield looks good. If you need one for a K we have them.
Old May 8, 2006 | 04:10 PM
wHOAlly's Avatar
15 mins is definately bullshit, yea, cuz it only takes like 10 mins w/o modding anything....haha....
ge gets a from me
Old May 9, 2006 | 03:09 AM
Mikey3000's Avatar
Default Re: Scatter Shields? (AkumaY)
did either of you install it on an H22?
Old May 9, 2006 | 05:18 AM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfeen &raquo;</TD></TR><TR><TD CLASS="quote">
.. i use the GE scatter shield and i didn't have any problems with it. matter a fact it only took us 10 min. to bolt it up. So i don't know why you were having any problems.</TD></TR></TABLE>
i have the GE shield as well, it wasnt 15 mins, but i did have to modify it a little, but only took a little over a half hour to install.
Old May 9, 2006 | 05:44 AM
Garcia-Racing's Avatar
I have the deist, it takes about 5 minutes to put on with a bunch of turbo crap in the way. Pretty easy.
Old May 9, 2006 | 06:20 AM
fast93accord's Avatar
the only con to the blanket is if you have any leaks it will get saturated and be very heavy... also if it gets wet with rain water the same will happen...
Old May 9, 2006 | 06:57 AM
SpeedDreamz.com's Avatar
Default Re: Scatter Shields? (fast93accord)
I had GE on both my b cars. It installed with no effort whatsoever. Now I use the Deist blanket on my wifed K motor and it is a little pain.
Old May 9, 2006 | 07:51 AM
SPOOLINmatt's Avatar
Default Re: Scatter Shields? (SpeedDreamz.com)
i got the mazworx, it was easy to install once you grinded the tabs required to grind off, which they told me before hand i was going to have to grind the tabs on the edge of the bell housing. top and bottom
Old May 9, 2006 | 08:19 AM
Mikey3000's Avatar
Default Re: Scatter Shields? (SPOOLINmatt)
in regards to the GE
a) has anyone installed it on an H22?
b) how well does it fit around the slave cylinder area?
Old May 9, 2006 | 03:49 PM
MF Doom's Avatar
trapped in my own room!
GE are best . The GE for the h22 is kinda tight but fits
you guys need shields at a great price hit up Tom at Camp1320.com
Fitsperfectly
Honda Fit
May 5, 2008 01:31 PM
siriussr
Northwest
66
Apr 20, 2008 01:18 AM
