Roll cage question
Old Dec 29, 2011 | 08:11 AM
  #26
Bizarre's Avatar
Default Re: Roll cage question
I'm not sure where in ohio you're located but there's one listed in here
http://www.nhradiv3.com/apcm/templat...4219&zoneid=22
Old Dec 29, 2011 | 08:57 AM
  #27
turbo-2nr's Avatar
call a nhra track
Old Dec 29, 2011 | 09:13 AM
  #28
Divers's Avatar
Originally Posted by theidealone
"All cage structures must have in their construction a cross bar for
seat bracing and as the shoulder harness attachment point; cross
bar must be installed no more than 4 inches below, and not above,
the driver’s shoulders, or to side bar. All required rear braces must
be installed at a minimum angle of 30 degrees from vertical
and
must be welded in. Side bar must pass the driver at a point midway
between the shoulder and elbow."
Taken from the 2011 Rulebook PDF
http://www.bremertonraceway.com/2011...20Rulebook.pdf
Under 4:11 Roll Cage (Section 20, Page 26)
Thanks for the post. For some reason I was thinking it was 30* from the trunk floor. Which would be impossible with rear seats, but 30* from vertical makes more sense. Should have no problem with that.
Old Dec 29, 2011 | 01:17 PM
  #29
MatthewFarrar's Avatar
Originally Posted by turbo-2nr
if it is a all motor car and dont go fast enuff to need a 10pt i would just put a 5pt in it to save weight, the passenger side door bar is not needed only the driver side
He's aiming for 10.8 at around 125. Right now, He ran a best of 11.3 at 120.
They wouldnt let him run again after that though because there wasnt a cage in the car.
Old Dec 29, 2011 | 01:23 PM
  #30
Steeve_Civic's Avatar
I would like to buy the Jegs one too.
http://www.jegs.com/i/Jegster/550/949201K/10002/-1
Any feedback of this roll cage installation?
Why don't they sell the 4 pts roll cage? We need to buy and weld the 5th bar?
GDM Ap1
Nov 14, 2005 02:46 PM
GuitarSlinger78
Mar 20, 2005 03:20 PM
NirVTEC
Mar 8, 2004 01:39 PM
X2BOARD
22
Mar 22, 2002 10:33 AM
