Roll Cage Question
Old Apr 19, 2008 | 09:17 PM
dmotoguy's Avatar
Default Roll Cage Question
I'm installing my cage and have a few questions..
1. My main hoop is within a 1/4" of my headliner, but with my helmet on my helmet is pretty much level or slightly below the top of the bar... so do I just need a lower seat? or is it fine to be up that high as long as im not touching the halo...
2. i think i have it sitting too far towards the rear of the car, it has to be 6" or less from the back of your helmet right?
Thanks.
Old Apr 20, 2008 | 05:17 AM
96 GSR-T's Avatar
The answers to your questions are right in the rule book, height wise you will be ok, but you have your hoop leaning to the rear of the car, and you need to lean it the other way. You flip the car the way it is now, and the roof is coming down on your helmet!
Old Apr 20, 2008 | 07:17 AM
jjspec's Avatar
Default Re: (96 GSR-T)
The main hoop can lean reward up to 20 degrees. I dont think you dan have any forward lean
Old Apr 20, 2008 | 07:33 AM
SPOOLINmatt's Avatar
Default Re: (jjspec)
forward lean is bad. The main hoop is supposed to be within 6" of your head and atleast 3" higher than the top of your helmet(but i think they go a little light on that). You need a racing seat to drop you lower. If you are not going to certify it then i wouldn't worry to much but if you are, make sure these things are addressed. Trim some off the bottom and make the bar stand up straiter.
Old Apr 20, 2008 | 10:05 AM
96 GSR-T's Avatar
Default Re: (SPOOLINmatt)
Section 4:11 3rd Paragraph "Main hoop may be laid back or forward" A little formard lean shouldnt hurt too much, but it is allowed. It really wouldnt matter IMO if it was a 10pt, but w/o the front half of car done I wouldnt lean it much forward.
Old Apr 20, 2008 | 08:55 PM
bigTom's Avatar
i always lean the main hoop back... it geberally fits better along with the contour of the seat. dont quote me but i believe the max setback for a hoop was either 17 or 18 degrees. i generally set them to anywhere between 10 and 15 anyway.
1989CivicSi
May 28, 2007 01:52 PM
Blue Si #72
Jan 13, 2006 02:15 PM
Masta
12
Feb 23, 2004 04:04 PM
4doorH22
25
Sep 11, 2002 08:28 PM
