roll cage pics
Old Feb 24, 2004 | 11:08 PM
Modify's Avatar
Default roll cage pics
it's done
all the rest is there:
http://www.imagestation.com/album/?id=4287738719
Old Feb 25, 2004 | 04:41 AM
MrCrx's Avatar
Default Re: roll cage pics (Modify)
Is that the correct place to mount the 2 rear bars on the strut towers to be nhra legal? rob
Old Feb 25, 2004 | 05:51 AM
30psi Teg's Avatar
Default Re: roll cage pics (MrCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrCrx &raquo;</TD></TR><TR><TD CLASS="quote">Is that the correct place to mount the 2 rear bars on the strut towers to be nhra legal? rob</TD></TR></TABLE>
Mine is NHRA certified and the to back bars are welded to a bar that links the strut towers together. So I would say his way is legal to.
Old Feb 25, 2004 | 06:30 AM
2ltrsnailpwr's Avatar
Default Re: roll cage pics (30psi Teg)
same here , im legal, my struts are linked, bars from halo connect to strut linking bar your good to go
Old Feb 25, 2004 | 06:51 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: roll cage pics (2ltrsnailpwr)
thats where mine sit as well. If you do a little research, theres liek a triplle layer of metal in that particular spot.
Old Feb 25, 2004 | 07:54 AM
racerxadam's Avatar
I thought all the plates had to be 6"x6". The plates that the rear bars are anchored to don't look that size to me.
Old Feb 25, 2004 | 04:57 PM
Bad-T's Avatar
How fast do you plan on going? this a sportfwd car?
Old Feb 25, 2004 | 09:00 PM
Big_Mike's Avatar
Default Re: roll cage pics (racerxadam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxadam &raquo;</TD></TR><TR><TD CLASS="quote">I thought all the plates had to be 6"x6". The plates that the rear bars are anchored to don't look that size to me. </TD></TR></TABLE>
that's what I was gonna say
Old Feb 25, 2004 | 11:52 PM
mister2racer's Avatar
looks good... can i see a pic of how it comes around in the dash area?
Old Feb 28, 2004 | 09:51 PM
XShadow's Avatar
Lovely, I wish my car wasn't a daily driver...
Old Mar 11, 2004 | 10:36 AM
Nextelbuddy's Avatar
Default Re: roll cage pics (XShadow)
i have the same cage i need to install. what kind of welder did you use for your cage?
Old Mar 12, 2004 | 04:25 PM
doublejz's Avatar
Default Re: roll cage pics (nextelbuddy)
i would use a tig, it might even help get the whole way around the bar better. But a mig works well too
Old Mar 12, 2004 | 06:09 PM
fknfast's Avatar
Default Re: roll cage pics (doublejz)
nice stuff
Old Mar 13, 2004 | 09:24 AM
00specR's Avatar
6"x6" on the 4-points in the driver compartment. the rule book isnt clear on if all plates have to be that size. most techs dont pay atttetion to the rule book. if u look carefully on most import race cars, there still missing 1 bar on each side of the car. they from the lower portion of the main hoop to the lower portion of the forward supports. the rule book marks it as an "A" tube. "A" tube = 1 5/8" x .120 MS and 1 5/8" x .083 CM. its the bar thats below the sidebar.
Old Mar 28, 2004 | 02:17 PM
L-CON1's Avatar
L/CON ENGINEERING (714)366-1711
RACECAR FABRICATION
BREA,CA
Old Mar 28, 2004 | 04:03 PM
Jared's Avatar
Default Re: (lcon)
Does a moly cage have to be TIG welded in? what about the plates?
Old Mar 28, 2004 | 07:49 PM
1 2 NV's Avatar
Default Re: (Jared)
it says right in the NHRA rulebook that a chromoly cage has to be tig welded.
Old Mar 28, 2004 | 07:59 PM
tony1's Avatar
Default Re: (Jared)
Right, plates can me mig welded to the floor, but chromoly tubes have to be tig welded.
Old Mar 28, 2004 | 10:47 PM
SiRkid's Avatar
nice! where did you get it done?
i wouldnt mind having a cage
Old Mar 28, 2004 | 11:28 PM
racerxadam's Avatar
Default Re: roll cage pics (00specR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00specR &raquo;</TD></TR><TR><TD CLASS="quote">6"x6" on the 4-points in the driver compartment. the rule book isnt clear on if all plates have to be that size. most techs dont pay atttetion to the rule book. if u look carefully on most import race cars, there still missing 1 bar on each side of the car. they from the lower portion of the main hoop to the lower portion of the forward supports. the rule book marks it as an "A" tube. "A" tube = 1 5/8" x .120 MS and 1 5/8" x .083 CM. its the bar thats below the sidebar. </TD></TR></TABLE>
pretty sure that extra tube you are talking about is for cages down to 7.50
Old Apr 4, 2004 | 04:35 PM
dfoxengr's Avatar
which type of metals are legal in most sactioning bodies?
size/type, and are there different types for different parts of the cage, or is it all the same kind of metal?
Old Apr 4, 2004 | 04:49 PM
SpeedDreamz.com's Avatar
Default Re: roll cage pics (hybridvteceg)
My civic has a Kens 10pt moly that is tig welded together. Then tig'd to 6x6 floor plates and the plates are mig'd to the floor. I hope this is legal.
Old Apr 4, 2004 | 06:19 PM
1fstcorrado's Avatar
Default Re: roll cage pics (30psiCiv)
1.mig welding plates to floor is legal with chromolly tubing, so long as chromolly tubing is tig welded to plates.
2. in the rule book it says when<U>bolting</U> plates to floor they must be 6x6
3. when it says welding to rocker must weld main hoop to
rocker sill area with .125-inch reinforcing plates, with plates welded
completely. <U>does not say that they need to be 6x6</U> although most people do it just to be on the safe side....as it all depends on the inspector....
hope this sheds some light
Old Apr 4, 2004 | 06:24 PM
dfoxengr's Avatar
Default Re: roll cage pics (1fstcorrado)
tubing type and sizes?
Old Apr 4, 2004 | 06:26 PM
chromolly or mild steel.....
rollbar is 1 3/4x .058 chromollhy
roll cage is 1 5/8x .058 chromolly
read the rules on nhras site.....
