Radiators blowing up??
Old Jan 17, 2007 | 11:42 AM
Jason703Racing's Avatar
Default Radiators blowing up??
What would make a radiator even a stock or aftermarket radiator blow up when going down the track? i was watchen a vid where the radiator blows up and the guy hits the wall pretty hard..
http://guelphracing.nstemp.com...f.wmv
So with this said what makes the radiators blow up durring a pass???
Old Jan 17, 2007 | 11:49 AM
skunked's Avatar
Default Re: Radiators blowing up?? (Black00em1)
I blew one up over the summer at the track. I had some cooling issues from air in the system along with a 12 year old stock radiator, the two didn't mix well
Old Jan 17, 2007 | 11:51 AM
A.E Motoring's Avatar
how do u know it was his radiator? looks like his right slick blew out, causing him to go left and hit the wall, i really dont think blowing up a radiator would do that.
Old Jan 17, 2007 | 11:57 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Radiators blowing up?? (Dual Cam Racing)
doesnt look like a blow out to me.. watch the "white" smoke 1-2 secs before they lost it.. that look slike collant smoke to me..
it blows out and all that on the motor/mani etc.... and with the rad on the right side of the car it cold have gotten on the tire hense turning left...
Modified by S@nt0s at 1:09 PM 1/17/2007
Old Jan 17, 2007 | 11:58 AM
underpressure02's Avatar
cracking a sleeve can cause the rad to blow.
Old Jan 17, 2007 | 11:59 AM
IHaveTurbos's Avatar
Well if you blow a HG the pressure is going to goto the radiator, and if you have a stocker with plastic caps it would be easy to bust.
Old Jan 17, 2007 | 12:09 PM
ninesecrx's Avatar
Default Re: (TurboElements.com)
Ouch, that video was pretty crazy! Hitting a wall like that at 140mph is not joke!
Old Jan 17, 2007 | 01:51 PM
R.S.AKIMOTO's Avatar
* B A N N E D *
Default Re: (ninesecrx)
Headgasket failure would cuase a sudden increase in the cooling systems pressure.
Old Jan 17, 2007 | 01:52 PM
TSXRacing's Avatar
is it possible he presorized the coolant system and blew the lower radiator hose?? looks like the coolant was coming out of the lower right side before the car turned into the wall.
Old Jan 17, 2007 | 01:55 PM
* B A N N E D *
Default Re: (TSXRacing)
DAMB...that sucks...!
Old Jan 17, 2007 | 04:11 PM
BoogieDownBrown's Avatar
Default Re: (R.S.AKIMOTO)
On our RWD Modified Celica. We would have issues like that due to a blown HeadGasket. Like some one said ealier....it pressurizes the system and blows fluid all over. Regular radiators are only rated for certain PSI.
So what we did to eliminate the problem was. Use an Intercooler for a radiator since intercoolers are rated for HI PSI. So now no more blown up or pregnant looking radiators.
One more thing...... It would be best to mount your overflow to the rear of the car(behind the rear wheels) So the extra coolant will drip behind all 4 wheels. We did that in our car as well.
Old Jan 17, 2007 | 10:36 PM
Migrana's Avatar
Default Re: (BoogieDownBrown)
yeap head gasket
vxtirent08
Mar 20, 2008 10:36 AM
oovvutt
25
Dec 25, 2007 02:56 PM
tkHBseries
Feb 19, 2005 06:48 PM
