race spec switch panel.
hey guys just purchased a switch panel from xenocron.im just looking for any advice on the best way to wire everything.car is just for track use.i would like to use the swithces for ign, fan,fuel pump,lights,and starter.
Does the panel come with a relay board like the arc panels or is it just a switch panel? If just switches I would used those to activate relays for everything
yea its just the switches. the car still has the oem fuse box and relays.
i might buy the race spec fused/relay box and make a nice panel to mount the ecu , relay box ect.
The switch panel is intended to be used as control for your relays. Ideally, you would also have an ECU output control some circuits as well. You can use a switch to 'turn on' the relay and an ECU output to control the relay.
This. And you can get all you need from him and also from Chris at Xenocron for the relays and switch panel.
GS8HFL21
Nov 9, 2005 06:56 AM
