Proper preloading
Old Mar 10, 2011 | 06:30 AM
  #26
JDMBrian's Avatar
Default Re: Proper preloading
Here is a video of me "pre-loading", hope it might help ya. Don't mind the loud and slow crx. It's just a stock 200k B18a with a straight pipe. That's it lol
[youtube]nHKyvXKlJgk[/youtube]
Old Mar 10, 2011 | 11:03 AM
  #27
lane91dx's Avatar
this is good stuff, I haven't broke any parts yet but with me tiny ef axles averything helps
Old Mar 11, 2011 | 04:09 AM
  #28
wolve's Avatar
hehe, right there
what does it run?
Old Mar 11, 2011 | 05:03 AM
  #29
jnv255's Avatar
The car needs to be in gear before you start a burnout
Old Mar 11, 2011 | 05:38 AM
  #30
JDMBrian's Avatar
Originally Posted by wolve
hehe, right there
what does it run?
15.0@94 in that video. But the quickest pass was a 14.7.
Yea yea Nick, lol. I sat and waited at the burnout box for like 5min due to a breakdown. I forgot...lol
Old Mar 11, 2011 | 06:04 AM
  #31
jnv255's Avatar
Haha, I couldn't resist. Your shifting looked good
Old Mar 19, 2011 | 02:46 AM
  #32
Boosted_B_Series's Avatar
I preload, but a bit different than most.
I don't drag it threw both staging lights with the ebrake up full throttle anti lag blairing. That seems hard on stuff.
I'm not on a protree, that takes too long, makes too much noise and heats the clutch too much for my liking.
I just drive up light the first staging light, pull the ebrake up slightly, drag it to the next staging light at a lower rpm.
First non staging light that goes off I'm up on the two step, 2nd non stage light, full throttle anti lag, then I start binding it up slipping the clutch and pulling harder on the ebrake.
I side step the clutch and drop the ebrake, off you go, feels the same as last time.
Old Mar 19, 2011 | 11:36 AM
  #33
1320em1's Avatar
^^^exactly how i do it.
Old Mar 4, 2021 | 09:56 AM
  #34
Cthongtavee's Avatar
preloading kills clutches
not as bad as you'd think but oh well.
anyhow, the idea of preloading is taking all the slack out of you driveline before you launch it. think of it like this:
- stand in front of a wall and punch it as hard as you can
- or stand in front of a wall, fist against the wall and press it as hard as you can
wich is going to hurt most you think?
that's about the difference your driveline/engine feels with or without preloading
if you preload harder then just taking the slack out of the driveline, then your also preloading your suspension/tires. preloading like this also reduces unsettling the car while launching and thus improving traction of the line and save parts.
wearing down your clutch faster is a small price to pay, considering you save a lot of cash on otherwise broken trannies, axles, diff's, etc. not even mentioning the faster ET's
👏🏼👏🏼👏🏼👏🏼👏🏼👏🏼 Great explanation
Old Mar 5, 2021 | 06:49 AM
  #35
weedburner's Avatar
My Hitmaster clutch hit controller stops your hand before it fully impacts the wall. We don't need no clutch wear'in pre-load!
Grant
Old Mar 22, 2021 | 02:38 AM
  #36
S.J.'s Avatar
Anybody familiar if the stock Honda LSD can take some pre-loading on boost?
My setup is stock b18c4 engine(European version of the b18c1) with a stock s9b gearbox and OEM Honda LSD. These gearboxes come with LSD from factory.
Also its running a T3/T4 turbo on max 9psi.
Should the stock LSD be able to take this kind of abuse or would a aftermarket diff be more recommended.
Old Mar 22, 2021 | 11:03 AM
  #37
1992Si's Avatar
I would say yes, for a while. remember your lowering the impact/shock to the driveline by preloading. unless you have upgraded the axles, which are normally the weak spot, you should be fine.
Nice to see some newer members asking about this. There used to be some good video's back in the day, showing how its done, about 2007.
Old Jan 17, 2022 | 07:34 PM
  #38
95dxsir2's Avatar
Yes the stock diff can handle it for awhile.
I was running a B16 with a t3t4 at 300whp.
Type R trans with stock lsd diff.
It had about 100 passes on it before I went with a different setup. I recommend getting axles (2.9's DSS) and use slicks, not drag radials.
wwolf771177
Mar 10, 2012 04:32 AM
Nicaraguense13
Mar 13, 2007 04:36 AM
kevpotts
Jun 9, 2005 12:50 PM
Dee A Nine
Sep 18, 2004 12:27 AM
zomart
Jul 23, 2003 05:51 PM
