PPG final drive cracks.?
1 Attachment(s)
Has anyone ever have this same problem?
Re: PPG final drive cracks.?
what size tire are you using and clutch?
Originally Posted by MARC P
(Post 49579684)
that's insane. is it literally cracked between every tooth? that is something i have never broke or cracked on a liberty dog box and a gforce dog box, the ring gear. and i know the ppg stuff is exponentially better quality than the two mentioned.
Excessive tire shake. Seen it before
that is a healthy crack job. My liberty has been through hell....ive cracked the pinion before but never the ring gear.
24.5s
Clutch master twin |
Never seen this before. Not even stock trannies. The only trans I've ever seen cracks on the ring gear is the gforce. They seem to do it about every 30-40 passes. But those cracks were horizontal. In your pic they are vertical. Just very weird.
What ring gear size is that? Gsr? What's the counter shaft look like? Tepid, u have seen these exact cracks before? |
Originally Posted by GodFather of Boost
(Post 49580960)
What ring gear size is that? Gsr? What's the counter shaft look like? Tepid, u have seen these exact cracks before? The counter shaft looks good. |
Seen it a few times on the PPG 4.6. If you look back a few years ago there is a lot of info about this.
(Post 49580960)
What ring gear size is that? Gsr? What's the counter shaft look like? Tepid, u have seen these exact cracks before? The newer stuff doesn't seem to have this issue. |
We have a few older ones like this as well, never broken one yet though.
Could be to tight against the counter shaft?
machining problem from the older units.
Can you get them all warrantied? :)
Originally Posted by tepid1
(Post 49581143)
Yes, that's why I said I've seen it before. The early revision gearsets had this issue. I've seen it on the early 4.4 and 4.6 finals.
The newer stuff doesn't seem to have this issue. Question is for op and locash also. If they are willing to share. I have notice on the gsr ring gear that it doesn't sit fluch with the diff. Had to machine the spool a couple mm smaller so it would sit flush. |
Originally Posted by BillyEG92
(Post 49580966)
4.4 gsr
| All times are GMT -8. The time now is 10:00 AM. |
