power shifting
Old Oct 31, 2004 | 04:32 PM
SLR ef9's Avatar
Default power shifting
just trying to figure out how much added wear and tear would powershifting to my tranny. i'm a low budget racer and need all the info i can get before i go and tear up my tranny.
Old Oct 31, 2004 | 05:08 PM
drvfast's Avatar
Default Re: power shifting (alphaprojectb16teg)
I powershift all the time. I have been doing it for over a year on my y21 tranny and it still shifts fine.
Old Oct 31, 2004 | 09:57 PM
Kataku2K3's Avatar
Default Re: power shifting (drvfast)
It's going to put more stress on your tranny (collars and synchros) anytime you shift fast as apose to shifting slow but if your tranny is okay to begin with then you'll be just fine. That's when full throttle shift/ignition cuts (built into some EMS and ignitions) are nice as they help to unload the tranny between shifts.
Old Nov 1, 2004 | 01:31 AM
DOHC_EG6's Avatar
i messed up my first trany by doing pawer shift (1 yr). i got a brand new trany (type r) ive been using it for almost a year and it still shifts good.
Old Nov 1, 2004 | 02:00 AM
turbo's blow's Avatar
I don't really like powershifting, I like to get my tires hooked back up as soon as possible. All my friends powershift and they have no problems so I say go for it if thats what you like.
Old Nov 7, 2004 | 01:10 PM
msmotorsports's Avatar
Power shifting will ultimately break your tranny its just a matter of time. If your are on a low budget I would suggest just shifting conventional until you get some cash to be able to support breaking stuff.
Old Nov 7, 2004 | 02:20 PM
quick_DC5's Avatar
You wanna go slow or you wanna go fast?
Old Nov 7, 2004 | 02:21 PM
93LSivic's Avatar
Default Re: power shifting (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">It's going to put more stress on your tranny (collars and synchros) anytime you shift fast as apose to shifting slow but if your tranny is okay to begin with then you'll be just fine. That's when full throttle shift/ignition cuts (built into some EMS and ignitions) are nice as they help to unload the tranny between shifts. </TD></TR></TABLE>
What kind of settings do you recommend for the aem ems ignition cut? Im kinda nervous to rev through it especially when I have the initial limiter set at 9500.
Old Nov 7, 2004 | 02:33 PM
TyCooley's Avatar
Default Re: power shifting (93LSivic)
"You wanna go slow or you wanna go fast?"
Old Nov 7, 2004 | 05:03 PM
b20flipside's Avatar
i messed up my 1sr tranny power shifting well it was only 3rd gear but i was still 250$ to fix , now all i do is shift fast
Old Nov 7, 2004 | 05:09 PM
88crx-si's Avatar
Default Re: power shifting (TyCooley)
one time i powershifted from 1-2 and then my shifter popped out of the bushing...luckily i was only a mile away from home so i drove home and checked it out..
i found out that the long bolts that held my shifter bushing in place moved ALOT.
about a 40 degree angle, weird. my friends think that it might have been the vibrations since i have those prothane bushings...but if you're gonna powershift and smash it into gear, be careful and check that out once a month.
Old Nov 8, 2004 | 12:50 AM
nevin's Avatar
it takes practice to do it perfect and consistantly. I recomend practicing on a dying tranny.
Old Nov 8, 2004 | 01:12 PM
Kataku2K3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry, I actually have never played with the AEM ignition cut/anti-lag so I really don't know what "settings" would be best. You might try talking with Tyler (Tyler's profile!) as he'd be a lot more knowledgable with the AEM than I. With most of the cars Scott and I build we just wire in an ignition cut over the MSD which isn't the greatest but seems to work fine.
turboef90
Transmission & Drivetrain
Apr 25, 2018 08:07 AM
ITRICED
Nov 9, 2009 07:39 PM
Laosakademiks
Mar 26, 2007 09:03 PM
