parachute mounting question.
just received my car back from the chassis shop and this is how they mounted my chute! they told me they mount all there chute this low.
has anyone see it this low? Will this cause any problems?
Thanks
Thanks
I would have mounted it about a foot higher, but it should still work. If the chute hits the ground obviously it won't deploy as it should. Just watch for that.
Any chance you can bend the chute plate to point upward more?
i can give it a try they have the bar waled to that plate.
the rest of the cage looks awesome and they also got it certified for me to. I was just worried about the chute mount.
I would have them mount it higher... if there is a question about your safety then I would have them change it. It wouldnt be hard to make it higher.
I will give them a call and see hate to haul the car back up there and back!
I mean if its not gonna cause problems then im fine with it just never seen it mounted like this The anchor point is what really matters from what ive read.
tether point is good. as for the chute itself, like mentioned, it wouldnt hurt to mount the chute higher or maybe tilt it "more" so itll shoot up more when deployed, but it does help that its a helper chute. you can always try it out and a moderate pass and have someone at the finish line take a video
look at the stroud instructions, there is a picture showing not to mount it like this. I wanted mine low too but to do it right it needed to be higher. even that tag line seems low.
Every fabricator has a mind of his own, you gotta stay on top of those fools no matter how great they are at what they do. I know when i go to redo my roll cage i will be there every day of the work to make sure its meticulously done how i envision it otherwise ill just want to vomit.
SJR
Apr 2, 2005 04:34 AM
