one-wire alternator?
Old Jan 26, 2011 | 08:23 AM
mikesrex's Avatar
Default one-wire alternator?
I'm thinking about switching to a one-wire alternator on the crx to simplify the car some more but wonder if I will encounter any problems with not having the ECU send (or get) signals from the alt while the car is running. I'm not familiar enough with the exact control scheme when it comes to what the stock Honda ECU does when it comes to the alternator. Does anyone here run a one-wire alternator or know if I would have problems running one? I'm about to rebuild one and this is one of the options I am given by my alternator guy.
FWIW the car is a 91 CRX HF converted to OBD1 running a P28 with a basic all motor setup. I tuned it using Crome Pro. So far it's run 12.0@110 but we haven't gotten a good run out of it since the alt took a crap lol. Hoping to get some 11 sec passes during the Houston IFO.
thanks
Mike
Old Jan 26, 2011 | 08:38 AM
Turbogixxer's Avatar
Default Re: one-wire alternator?
The ECU just sends a low charge output. You can disable it on a stock alt and do the same thing. You just have to power the alt with the blk/yel or run a one wire alt.
Old Jan 26, 2011 | 08:47 AM
mikesrex's Avatar
thanks for the info. so there shouldn't be any problems running a one-wire?
Old Jan 26, 2011 | 08:52 AM
B18c1turboedEK's Avatar
Out of the 4 wires going too the ALt, you just need a 12v going too it to turn it on?
Old Jan 26, 2011 | 09:13 AM
redboost10's Avatar
I only had one wire going to the alternator. It does simplify it. Can't tell you the color because it was a custom harness.
Old Jan 26, 2011 | 09:34 AM
tepid1's Avatar
That is true.
Old Jan 26, 2011 | 01:42 PM
E Town DSM's Avatar
i run one on my car idles at like high 13's and stays at a steady 14.5 at full throttle
Old Jan 26, 2011 | 02:03 PM
mikesrex's Avatar
are you still on ECU or a standalone?
Old Jan 26, 2011 | 02:52 PM
E Town DSM's Avatar
aem
Old Jan 26, 2011 | 02:59 PM
.adam.'s Avatar
would this only be an option if you had a standalone or could hondata users do this also? seems like the other wires are there for some reason.....
Old Jan 26, 2011 | 03:06 PM
The other wires tell the ecu the voltage its putting out I belive..
Old Jan 26, 2011 | 05:16 PM
turbociv910's Avatar
black and yel wire needs power, rest is for dash dummy light. cut them off.
Old Jan 26, 2011 | 07:46 PM
Two of them are for the dummy lights, the other is a low/high charge circuit. You can remove all of them BESIDES the Black/yellow wire. It needs that to charge the battery. No 12v going to the black/yellow wire, not charging alt.
Old Jan 26, 2011 | 07:53 PM
Will_H's Avatar
i'm kinda in the same boat... So you need the plug but only the black yellow wire and just a main power?
Old Jan 26, 2011 | 07:54 PM
Correct.
Old Jan 26, 2011 | 08:11 PM
Redline130's Avatar
I only run the blk/yel wire with my S300. No issues at all.
Old Jan 26, 2011 | 08:29 PM
EDLOVA23's Avatar
what are the benefits of running ONE wire?
Old Jan 26, 2011 | 08:39 PM
redboost10's Avatar
Less wires to run and no point in running unneeded wires on some of these standalone ecus since they are logging voltage.
edit: logging was the wrong term, i meant to say it like what tepid is saying.
Old Jan 27, 2011 | 03:30 AM
How does it log voltage if you cut those wires off? I could have sworn one of the wires tells the ecu the voltage. If not where are you getting the data for voltage? Does the ecu read it elsewhere?
Old Jan 27, 2011 | 05:09 AM
tepid1's Avatar
I thought the ECU reads input voltage to the ECU itself. It's onboard measurement.
Old Jan 27, 2011 | 07:05 AM
OBD1 ECUs (honda) reads the voltage from the power voltage inputs to the ECU (A25).
Old Jan 27, 2011 | 07:46 AM
xenocron's Avatar
keeps the voltage in the "system" steady.
in a factory vehicle the alternator will go into low mode and run the vehicle at around 12.5-13 volts when there arent a whole lot of accessories on that will pull much current
when the A/C, rad fan, high beams...etc are on it will go into HIGH mode 14 - 14.5 volts to supply more voltage to these accessories to keep the current in the circuits down.
Old Jan 27, 2011 | 07:53 AM
mikesrex's Avatar
thanks for the info guys. I'll post my results once I am done with it.
Old Jan 27, 2011 | 09:47 AM
EDLOVA23's Avatar
so it will always keep the voltage @ 14-14.5 volts once the car is started with only the blk/yel wire connect which is signal correct?
Old Jan 27, 2011 | 11:45 AM
tepid1's Avatar
I believe it defaults to the "high" with no feedback to the alt. I get 14.5vdc out of mine with just the one wire.
