Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts! 2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it. 3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned 4) NO WTB ADS! 5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE 6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
k20a2 block stock sleeve stock crank Brian crower rod with upgraded 625+ rod bolts and pins
CP pistons 10:1 compression
Prayoonto stage 2 all motor cams
Supertech dual valve springs and retainers stock valves and ferra keepers
OEM head gasket
stock k20a2 oil pump
TD autowerks modified crank gear with key way instead of stock dimple
new timing chain and oil pump chain and oem tensioner
ACL main and rod bearings
Has h11 headstuds
motor was built for street use 750 whp was the goal
ZERO miles on all after market parts minus cams were used for a brief time in another car
k-tuned water neck
k-tuned water block off plate
asking 3200 shipped! dont be afraid to shoot me an offer
sheepey built gangster lean manifold
t4 open
60mm gate
BRAND NEW! only used for mock up
850 shipped
prayoonto gangster lean mounts for eg/dc
solid inserts
brand new only used for mock up
comes with all hardware and brackets
600 shipped
H22 Turbo Manifold - $500
Built by Innovative Turbo Sysytems back in 2003. Was fully polished, bead blasted now. T4 single scroll and two bolt 38mm wg flange. Thick wall stainless steel TIG welded construction. Very durable, been used on a street car for years. I'll include an adapter to run a 44mm v-band wg. Including downpipe too.
99-00 Carbon Fiber Hood with Custom Scoop for Full Race K24 manifold - $200
Tilton H22 Cerametallic Twin Disk Clutch - $750
Less than 10 passes. Excellent condition. Had my machinist clean up the flywheel bolt mounting surface, it got a bit worn.
H22 CNC Ported Cylinder Head. Ported by R&D Dyno Service. - $400
Includes cam caps, rocker assemblies, shafts, LMAs, dual springs and Ti retainers. Intake #3 has full valve guides, all other ports are cut back to the port wall. I'd recommend getting new springs and retainers.
S2000 bare metal acid dipped rolling chassis chassis, perfect for building a race/drag/drift car.
Also has great working transmission and used stock engine
Customer ended up going to a v8 project...
$2999
make trades/offers call or PM for details!
EK Civic Acid Dipped with chromoly tig welded roll cage rolling chassis
$2999 - call or PM for details
Full Race prototype top mount manifold. O2 bungs capped and welded, twin gates. Twin scroll T4 mounting base. This was sold to me as a prototype for the ones full race sell now. It is in great condition, with no cracks or issues at all. Going to a different setup. $400
Gates Sold
F/S hondata s300 v1 with bbg and coil on plug. Also comes with billet dizzy cover and 4140 coil hold down plate. With a rywire engine harness made by rywire for plug and play option for the cop wiring. 1400 shipped.
ATS/Carbonetic Twin Disk Carbon/Carbon Clutch.
Purchased in 2012 and used for 2 seasons. I bought a rebuild kit for it from ATS who are the manufacturers of the clutch on behalf of Carbonetic last year to have as a spare. The clutch was used in our Time Attack car, and held 400whp and 250ft/lbs of torque without any issues. Removed from the car in perfect condition, we decided to go with something simpler and less aggressive.
This clutch has the 1350kg pressure plate option. The clutch has an MSRP of $2600 brand new, and the rebuild kit was another $1400.
Asking $1500USD plus shipping. Item is located in Canada but international and shipping to the US can be arranged.
PLM K Series T3/44mm Sidewinder Manifold with Uppipe and Dump Tube
PTE 6766 CEA
PTE 46mm Wastegate
3" Custom Piping w/ Vanjen Clamps and V Band Clamps
Tial BOV on End Tank
w/ Oil Lines
Im posting this for a friend of mine... His priorities changed and decided to sell his car... If interested pls call/text me at 510 415-0544 or (408) 824-8773 for additional information...
Call or text for faster response
1996 honda civic
780 hp (mustang dyno)
best time 9.4
Best trap 156
BLOCK:
84 mm gsr
Close deck rs sleeve
10.5 arias pistons
Pauter rods
acl race bearings
HEAD:
Gsr gead
Ported and polish
Skunk2 pro 1 cams
Supertech valves (inconel ex)
Supertech valve springs
Supertech retainers
Skunk2 ultra manifold
90 mm throttle body
TURBO:
Sheepy front facing manifold
Sheepy intercooler
Sheepy dp
(2) 44mm tial wg
Borg warner 67mm
Motec M4 Pro with custom pro style wiring harness built by Motec USA and modified by T1.
Asking Price: $2500obo (Retail was over $5100)
Items included:
- M4 Pro
- Honda B-series engine harness (built by Motec and modified by T1 Race Development)
- Two sets of Motec twin-coil boxes with integral igniters (one is used, the other is brand new)
- Motec Ignition Multiplexor (brand new)
- Motec Traction Control Multiplexor (brand new)
Details on the setup:
The M4 kit was originally purchased through Motec USA by Jerry Woods Enterprises (World Renowned Porsche Race Car Builder). The Motec harness was then modified to “Outlaw Spec” by T1 Race Development in 2009.
The M4 includes the upgraded advanced tuning option (Pro):
-Traction Control and Launch Control (2, 3 or 4 wheel)
-Gear Change Ignition Cuts
-Overrun Boost Enhancement (anti-lag)
-Ground Speed Limiting
-3D Mapping of Individual cylinder fuel and ignition tables
-Start/End of Injection Calibration
-Ignition Accel/Decel Calibration
-Ignition Dwell Table
-Second Load Fuel/Timing Table
-512 kB internal logging memory
-Wideband lambda control
The Motec built harness also includes the following T1 “Outlaw Spec” modifications:
-Pre-wired for 4 or 8 sequential fuel injectors (the secondary set of injectors runs in parallel off the first set). The Injector clips are USCAR style (for Injector Dynamics ID1000 style injectors).
-Pre-wired for individual coil setup via a Motec Ignition Multiplexer, but also has previsions for a dual coil wasted spark ignition.
-Pre-wired for a cam trigger ignition but can be repinned to use the included Motec modified stock Honda distributor (the harness is pre-wired for both styles).
-Pre-wired for a Strain Gauge (This output can also be used for other purposes)
-Pre-wired for Traction Control via the included Motec Traction Control multiplexer (This output can be used for other purposes).
-Pre-wired for both a 1-3bar GM/Delco map sensor or 5bar Kavlico map senor (via the included GM to Kavlico adapter harness)
-Pre-wired to control an air valve solenoid (The setup includes a GM/Delco boost control solenoid). The output can also be used for other purposes.
-Pre-wired to use an OEM Honda coolant temp sensor
-Pre-wired to use a high-speed GM air temp sensor
-Pre-wired for a Honda VTEC setup or other auxiliary output
-Pre-wired for a 4-wire lambda connection
All documentation, receipts & diagrams are included. The condition of the M4 is excellent.
Note: The M&W Pro Drag 4 ignition box shown in the picture is NOT included.
Two working Honda B-Series turbo basemaps are also included (one for a multi-coil coil “T1 style” ignition and one for the twin coil Motec ignition). The twin-coil/ 4-injector base map has made over 750whp. The multi-coil/ 8-injector map has made over 900whp.
FS: Go-AutoWorks triple core aluminum radiator. Fits 92-00 Civic, 94-01 Integra, etc. Good condition and cost $200 new. Almost 3" thick core on this radiator.
Price $130 shipped for the radiator!
Moroso Pan heater $20
ARP B-series head studs missing 1 washer $50
Manley turbo tuff LS rods with 84mm CP 10:1 pistons with heavy duty wrist pins. Spun a rod bearing 1 rod is probably toast. Very little run time.$400
Autometer tach/shift light like new: $200
Avid solid mounts passenger is a auto to manual mount $250
Integra shift linkages with skunk 2 short shifter and (**** sold) with pro-thane bushings $75
B series swap mounts with prothane inserts. T bracket is from a 94-01 Integra along with all the mounts. $100 Avid torque mounts have been sold
MSD cap PN 8292 with MSD wires $50
Done with Hondas so this stuff has gotta go!
NO TRADES. PM me for any questions or more pictures.
Hey everyone. I have a few things for sale to fund next seasons build. All parts are in good shape and only have 1 season on them, unless otherwise stated. I dont have pictures on this computer, but I will upload them tonight when I get home. All parts used. And all prices are firm, unless otherwise noted. Paypal add 3%
Serious inquiries only.
Cams and injectors were used in my all motor setup and made 225 on c16 and 232.9 on c45. These numbers were on a dyno dynamics which reads lower than a dynojet. So dynojet numbers are estimated around 250 on c16 and 260 on c45. The car was in the AMS class (full interior and exhaust) and ran 11.9 @ 114mph.
The boost control selenoid and map sensor was used on my turbo setup and helped make 800hp and ran a 10.02 @ 150.5mph.
You can PM me here or text me. Ill get back to you when I can. 580-382-1661
MAC boost control solenoid w/mounting bracket. Bought from T1 racedevelopment and used for 2 1/2 seasons. Working great before I pulled it off. - $75 obo
CNC inline staging brake. Used for 1 season. - SOLD
AEM 5 bar map sensor w/milspec wired plug. Everything origonal included. Used 1 season - sold
Kelford B series cams. 176-C. These are the second biggest cams Kelford makes and they sound mean! Made over 200hp on the primaries before we even messed with the vtec lobes. And that was on a dyno dynamics, so it made more on a dynojet. These are 750 new. Used for 1 season and only with Brad Penn racing oil. The cams are still in the motor, so I couldnt get a picture of them yet. But here is the cam card. - SOLD
K-tuned 410cc RDX injectors with B series hats and pigtails. Fuel rail and manifold not included. - $180 obo shipped
b series cc twin disk type c for sale off of my sfwd integra upgrading to triple disk no longer need this one it has 5 dyno sessions max power 880hp one pull every other pull was under that the pressure plate as you can see was rubbing the weld bracket on my dog box case but did not damage the clutch its fine and still works perfect I recommend you grind the small pieces that are left to clean it up some price is 670 shipped what you see is what you get.
Deatschwerks 1300cc. Just upgraded to 2200cc. Used for year on my daily has around 15k miles in great working condition. Comes with plugnplay adapter and o-rings are still in great condition. $260obo Plus shipping.
CNC machined bungs and filter tubes
Interanally baffled design to keep oil inside breather tank
Fully tig welded
Anodized Black
Laser etched logo
3 Earls Ano Tuff -10 Caps Included
3 New Filters with Chrome Tops as pictured Included
Brand new, never used
Stainless Steel
Megaphone with reverse cone
Anti reversion chambers on each runner
O2 bungs in each runner and 1 in megaphone
4 ports matched plugs for each O2 bung when not in use
3 step header design - 1 3/4", 1 7/8", 2", 2 1/8" exit
No waiting several weeks for a race header, this one is ready to go
Brand NEW OEM Honda K24 oil pan - $80 FREE Shipping
Oil pan was only used to cover bottom end while assembling engine
RSX Type S shift Box & Cables - $200 FREE Shipping
Used shifter box and cables in excellent condition
Box already trimmed and ready for install in a swapped car or great spare parts to have
