need help tapping compressor cover!!!!
Old Feb 18, 2009 | 08:36 AM
JBLAZE622's Avatar
Default need help tapping compressor cover!!!!
i'm gonna be tapping the compressor cover on my turbo to 1/8 NPT i was just wondering what drill bit size to use to do this? i borrowed the tap from someone and they did'nt have the drill bit that came with the kit.
Old Feb 18, 2009 | 08:42 AM
Turbo-charged's Avatar
Default Re: need help tapping compressor cover!!!!
you use a 21/64th drill bit. the tap is tapered so make sure not to thread it too deep!
Old Feb 18, 2009 | 08:51 AM
boostedcivicsir's Avatar
Mr. Badwrench
troof. it is a 21/64th.
Old Feb 18, 2009 | 09:06 AM
JBLAZE622's Avatar
thanks guys
Old Feb 18, 2009 | 11:03 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Huh?? I think I'm being stupid, but most through taps are tapered, and bottom taps aren't. But if you're drilling all the way through it shouldn't matter which tap you use, but you'd want to run a through tap, allthe way through to get an accurate size
Please correct me if I'm wrong
Old Feb 18, 2009 | 11:21 AM
depends on the tap being used. i cant count how many times i have seen people try to tap something.....oil pan, compressor housing, whatever else. they run the tap through too far, and go to thread in whatever fitting it is that they are using but they went too far with the tapered tap and the fitting would not properly tighten.
moral of the story is take your time and be careful. its a lot easier to run the tap half way through...pull it out and see if its enough...and insert the tap back in if needed than it is to "repair" something after you blasted a hole through it thats too big for your fitting.
Old Feb 18, 2009 | 11:46 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Just curious, could this be from using a regular tap vs an NPT tap?
Old Feb 18, 2009 | 12:48 PM
Mr. Badwrench
i think i see where you are getting switched up clayton, normal taps have a tapered start. a NPT (national pipe tapered) like bspt (which i think is british standard pipe tapered) has a smaller diameter at the bottom and continues to get bigger in diameter as you go. NPT fittings are the same way they are tapered like the tap. thats how they seal. like joe said if you burry the thing it bottoms out and doesnt seal. it is designed to seal on the threads.
Old Feb 18, 2009 | 12:51 PM
Mr. Badwrench
also its not like you will fond a 6mm x 1.0 npt......the NPT designates it is a pipe thread. on the same note there is no 1/4 x 20 npt. there is a whole pipe chart somewhere i cant remember where it is, the 1/8th NPT is 1/8 x 27 and 1/8 bspt is 1/8 x 28
man im confusing myself. he hee
Old Feb 18, 2009 | 03:08 PM
Drew Peacock's Avatar
What kind of a tap would you use to put in intercooler piping? Any pics?
Old Feb 18, 2009 | 03:32 PM
1junkycivic's Avatar
Why tap the cover?
Old Feb 18, 2009 | 05:53 PM
sweetfwdthunder's Avatar
To put a fitting for the wastegate/boost controller.
Old Feb 18, 2009 | 05:57 PM
intercooler piping is too thin IMO. if the comp housing is not an option, i drill a hole and weld a bung onto the pipe. gives the fitting a lot more meat to grab onto.
"Why tap the cover? "
its easier than welding to a charge pipe as it is thick enough to drill and tap. if you can help it you do not want to us a vacuum source (aka intake manifold / vacuum manifold) for your boost reference on your wastegate.
Old Feb 18, 2009 | 06:08 PM
Autoworks's Avatar
Just did this on my setup today actually. Good info. Question answered
Old Feb 18, 2009 | 06:15 PM
rota92
Guest
Posts: n/a
An 'R' bit is the proper bit, I have a few letter index bits but not a full set lol
http://www.newmantools.com/tapdrill.htm
I have a bunch of starrett quick referance cards in my tool boxes, those come in handy if you're ever around them. Swipe them and put them all over lol
Old Feb 19, 2009 | 05:32 AM
Honda1949's Avatar
Hi...Turbo charged....In regards to tapping the comp cover, I just talked with the guys from bullseye and they told me not to tap the cover but pickup the boost signal from the intake mani, not to start a **** storm but why the difference in opinion....Thanks
Old Feb 19, 2009 | 05:58 AM
well........ 99.9% of us use Tial wastegates. tial strongly suggests not to run vacuum to their wastegates. that is one of the main reasons.
the other way to look at it, is if you have say a 7psi spring, and you want the wastegate to open at 7psi manifold pressure....... its a little more "exact" if your supplying its signal from the manifold. however if there is a boost controller in the equation that kind of goes out the window.
that and they probably dont want to tell you to drill holes in your turbo just incase you screw it up LOL
Old Feb 19, 2009 | 06:13 AM
uglyasscivic's Avatar
I always tap the housings or the IC endtank depending on the setup. 1/8npt or sometimes 1/4npt. I would hate to run all that extra line/hose from the IM. While tapping use some wd40 or cutting oil for cleaner tapping.
Old Feb 19, 2009 | 06:16 AM
JBLAZE622's Avatar
this is true last year i ran my pressure source off the back of the intake manifold and my boost controller was all ****ed up it would make the boost jump around
Old Feb 19, 2009 | 08:45 AM
Will this help you boost more or just to be more accurate?
Old Feb 19, 2009 | 10:40 AM
Mr. Badwrench
accurate and consistent.
Old Feb 19, 2009 | 11:07 AM
PPossible more boost to?
93grayeg
Feb 18, 2013 10:12 PM
b00st4life
Dec 23, 2011 03:20 AM
wade
Jan 16, 2009 12:19 PM
integlspwr2k
Apr 10, 2005 10:25 PM
