need help selecting slick size
Old Oct 31, 2002 | 05:26 AM
Jeff C's Avatar
Default need help selecting slick size
<U>The setup:</U> 89 CRX Si (complete stock trim except drivetrain) w/ CRVTEC w/ 93 GSR tranny and no LSD ( should have spent the extra $800) and I have a 100 shot nitrous setup for it too, but not hooked up yet.
<U>Motor specs:</U> 1g B16 head w/ ITR cams and outer v. springs, portflow ti retainers and inner v. springs; stock bore B20B4 block w/ 10.5:1 JE's on Eagle rods; Exedy clutch and CM flywheel; chipped P28 ecu w/ Vision chip.
<U>My problem:</U> The car spins......and spins.......and spins more. I ran it at the track last week and it spun the entire 1/8th mile without hesitation. It runs 10.1's @ 75 on some good treaded Yok radials. So I want slicks, but I dont want to have to bend my fenders or buy aftermarket wheels yet, unless I have to. It was suggested to me to get some 22x8's or 24x8's. Also, I would like to put them on my stock 14" CRX wheels.
<U>My questions:</U> Are these sizes good for my setup? Does anybody have other suggestions? Should I get LSD first? Will they fit my CRX without fender mods? Are M/T pretty much the norm? Where can I buy slicks?
[Modified by Jeff C, 9:27 AM 10/31/2002]
Old Oct 31, 2002 | 05:46 AM
ExospeedAMcrx's Avatar
Default Re: need help selecting slick size (Jeff C)
the most common slick size is the 22x8x13, which sounds like something that would be good for you to start out with.
the thing is, I would scrap the 14" rim idea cuz there are no slicks that would fit that rim tha would be good for your application. there are 2 sizes in the 14" but they are small and you would probably spin those too. stepup to a 13" rim and there is a whole selection of tires to choose from.
We stock the M&H s22x8x13 and that would be a good start for you. a 24.5x8.5x13 might clear your fenders but I would have a coilover suspension just in case before I get those or raise your car up back to stock height.
Wil
Old Oct 31, 2002 | 05:50 AM
simple4012's Avatar
New User
Default Re: need help selecting slick size (exospeedAMcrx)
yea id say 22's especially with a cable tranny
Old Oct 31, 2002 | 05:55 AM
Jeff C's Avatar
...and would those fit on a stock 13" steelie? If so, good, cause I've 2 sets laying around.
How much do they cost?
EDIT: Nevermind on the price...I visited the site, 13x8x22.....$159.95.
[Modified by Jeff C, 9:57 AM 10/31/2002]
Old Oct 31, 2002 | 07:56 AM
the stock steelies are only 5.5 inch wide. the rule on slicks is that it would fit only on a + or - 1 inch wide rim. so an 8" slick is best with an 8 inch wide rim but can fit on a 7-9 wide rim.
Old Oct 31, 2002 | 03:48 PM
G-reX's Avatar
I run a 8 inch slick on a 6 inch rim and they work great, but the closer to the size of the slick is better. As for stock steelies i used a set of 13 * 6" wide rims off a Chev Vega.
Old Oct 31, 2002 | 04:41 PM
speedworks's Avatar
Default Re: need help selecting slick size (G-reX)
bump for the tn. guy
Old Nov 1, 2002 | 06:01 AM
Jeff C's Avatar
Thanks G-reX, but I dont want to be pushing it too much. Althought that is an idea, Vega wheels that is. I am not sure that I would tell anybody what they were off of though .
Any other ideas on some decent cheap wheels, possibly wheels I can find in the junkyard?
Old Nov 1, 2002 | 01:31 PM
91CivicSi's Avatar
Default Re: need help selecting slick size (speedworks)
TTT for my pit crew chief. He's not kidding about spinning..it spun the 185/60/14s the whole way down the 1/8th mile. The 100 shot will be useless without slicks. Who knows, it may be useless with slicks, too .
Old Nov 2, 2002 | 03:10 AM
Mista Bone's Avatar
D Tranny Guru
Diamonds or Circle Racing............
Wil at Exospeed happens to carry Circle Racing.......weird eh?
(shameless plug!)
Old Nov 2, 2002 | 09:49 AM
Default Re: need help selecting slick size (Mista Bone)
i have some Dope new WELDS too! new RAcelite. 6-7lbs for the 13's
they even have a 17" street version that is only 11lbs.
i dont have pics up on the site yet.. but email me if you want to see them.
MISTA BONE
[Modified by exospeedAMcrx, 6:49 PM 11/2/2002]
Old Nov 3, 2002 | 09:11 AM
Jeff C's Avatar
Are they going to be cheaper than the Bogarts?
I am assuming that they will be avaliable in say a 13x8, right?
Also, am I going to have to look into spacers and extended studs?
I will send you an email.
Old Nov 4, 2002 | 01:15 PM
Jeff C's Avatar
Where can I get these? They arent on exospeeds site.
Old Nov 4, 2002 | 02:10 PM
did you email me yet? sorry if i havent replied.
i havent had time to upload alot of stuff on the site. i'll email you some wheel pics if interested.
Wil
Old Nov 5, 2002 | 05:35 AM
Jeff C's Avatar
Yea, I got a reply from "W. N." &lt;crex22@yahoo.com&gt;, is that not you?
I am interested in some drag wheels, but it seems that they are all out of my price range at the moment.
[Modified by Jeff C, 9:43 AM 11/5/2002]
Slow-EJ8-4Now
May 6, 2006 09:35 PM
buttsneeze
Jan 31, 2006 07:22 PM
theclutchpoppa
Apr 21, 2003 01:14 PM
allmotorhonda
Sep 24, 2002 03:44 AM
