Hey, everyone wondering if you could help me out. I've been looking for the NOPI Comp 4 rules. I've found the NHRA street stock one which was no problem. Also looked on NOPI's site in rulebook and nothing. Any help would be appreciated. Thanks everyone
check on nopi forums, supposedly all the info is there.
franklin
look under the power street rules they merged power street and comp 4 together
Yeah man Comp 4 doesn't exist anymore, so I would build the car for NHRA
That is always a safe bet...they rarely change rules and when they do they aren't off the wall drastic stuff.
That is always a safe bet...they rarely change rules and when they do they aren't off the wall drastic stuff.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston »</TD></TR><TR><TD CLASS="quote">Yeah man Comp 4 doesn't exist anymore, so I would build the car for NHRA
That is always a safe bet...they rarely change rules and when they do they aren't off the wall drastic stuff.</TD></TR></TABLE>
correct. NOPI no longer exists in my eyes. comp4 has been merged with power street. they are attempting to merge the comp4 cars with that class. look under those rules.
That is always a safe bet...they rarely change rules and when they do they aren't off the wall drastic stuff.</TD></TR></TABLE>correct. NOPI no longer exists in my eyes. comp4 has been merged with power street. they are attempting to merge the comp4 cars with that class. look under those rules.
yup, NA cars are sheep to the slaughter in Power Street this year.
Thanks guys, I've been looking for all rules and couldn't find anything. So they're merging the 2 classes to power street? DANG! I looked in the NOPI forum and nothing about weight or anything. Do you guys think its best to just following NHRA rules? I guess a gotta call Mr. Woods. But if anyone finds the link, hook it up. Thanks again guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing »</TD></TR><TR><TD CLASS="quote">
jeez lol...
yeah comp 4 is not a class anymore.. Have fun with the turbo cars!
jeez lol...
If it were a FWD only class, I would say a healthy progressive shot would do some damage to those turbo cars....but then again you gotta race the AWDs so it doesn't matter anyway.
take away the turbo bias plys, we're decently competitive. until then, we're screwed
1.7> POWER STREET:
Engine Diaper or Engine Pan mandatory on all forced induction cars 9.59 and quicker. SFI approved 38.1 head and neck restraint system required for all 9.59 and quicker cars.
SPONSOR DECALS: All racers must have series and or class sponsor decals as required by NDRA. Competitors can utilize a competing sponsor product / logo.
CLASS: The class designation (PW/S) must be on the right side and the front window in 3-inch tall letters.
NUMBERS: Car numbers must be on the right side window in 6-inch tall numbers, and the front windshield in 3-inch tall numbers.
BODY: Stock import or domestic compact car or truck body must be retained. No cutting of fenders to fit larger tires. Lightweight parts limited to hood, fenders and ground effects only. Due to most sunroofs not being safety glass, sunroof plugs allowed. No cutting or drilling of body or chassis or removal of other components for purpose of lightening vehicle prohibited. However the rear bumper supports may be removed. Chop tops not allowed. Lexan or Plexiglas windows are prohibited. No tape can be used to join/cover body seams. Body or paint damage incurred at that event can be fixed by any means for remainder of the event.
INTERIOR: All interior, Seats, Door panels, dash, headliner and carpet must remain in place. Doors must work from inside and outside of vehicle. Windows and door switches must work as designed by manufacturer. Cars will be re-inspected on the return road; any cars found missing required components shall be disqualified. Stock steering column and turn signals most be retained. N/A cars are allowed to remove interior from behind the front seats to the rear of the car.
ENGINE: 4 cylinder FWD/AWD entries with 1 power adder allowed, 6 cylinder FWD entries with 1 power adder allowed. FWD N/A cars allowed slicks for competition as single power adder. Engine must be the some make as vehicle racing. Bolt on modifications only. Aftermarket cams, headwork, valves, cam gears and other internal modifications allowed. Approved aftermarket blocks allowed. No air-cooled entries. Turbo size at this time is 66mm (max size 67.80mm).
INTERCOOLERS: Air to Air only, no liquid or liquid to air intercoolers allowed. All Intercooler components must remain under the hood in the engine bay area.
CYLINDER HEADS: Must be commercially available, produced in runs of 500 or more. No billet cylinder heads. Any Internal modification permitted.
INDUCTION SYSTEMS: Any commercially available induction may be used, but stock configuration must be retained. Ex: Fuel injected entries must remain fuel injected, with the same type of injection used as delivered stock.
Example: if the car is delivered from the factory in a single throttle body configuration it must remain as a single throttle body.
EXHAUST SYSTEM: NDRA requires the use of a full exhaust system on forced induction cars in this class. All forced induction exhaust systems must exit behind the rear axle.Can N/A cars run open header ?
DRIVE TRAIN: FWD, AWD and RWD entries. Stock drive train configuration required. Stock rear end must be used.
* Rear ends: O.E. bolt in differential casing allowed. No aftermarket substitutes allowed. Examples (8.8, 9, or 12 bolt). If vehicle comes stock with I.R.S., vehicle must stay that way for competition.
TRANSMISSION: Factory available OEM manual gearbox / with a H-Pattern shifter or factory automatic transmission allowed. Modifications limited to what fits completely within stock transmission and bell housing. Scatter-shield required if 11.99 or quicker. See section 4.15 for additional details. No aftermarket Transmissions of any kind allowed. Absolutely no trans-brakes allowed.
CLUTCH/FLYWHEEL AND FLYWHEEL SHIELD: After market clutch and flywheel shield required if car is running 11.99 or quicker. See section 4.13 and 4.16 in general regulations
CHASSIS: Full stock chassis (Full stock floor pan) required. A roll bar is mandatory in all cars running 11.99 or quicker and in convertibles running 13.99 or quicker. A roll cage is mandatory if the car exceeds 135mph in the Ό. Any vehicle equipped with a roll bar must be equipped with a padded head protector to be placed behind the driver's head mounted in such a way so as to help minimize the risk of whiplash. The cage or roll bar must also be fitted with padding in any area where it may come in contact with the driver's helmet. Padding with Ό inch compression or padding meeting SFI Spec 45.1 padding or better shall be used. No other forms of padding will be accepted.
SUSPENSION: Must use one shock per wheel, or retain original style suspension. Coil-over shocks allowed. No wheelie bars allowed. Stock shock towers must remain completely intact front and rear. Roll bar may be attached to shock towers. Stock pieces may be strengthened. REAR: Entire rear sub frame structure must remain intact. The entire rear portion of the strut mount must also remain intact. Lower control arm alterations limited to lengthening or strengthening. Back half conversions not permitted.
WHEELBASE: Stock wheelbase must be retained.
IGNITION SYSTEM: Aftermarket crank triggers, two-step rev limiters, ignition amplifiers, spark computers or dynamically adjustable engine management systems and piggyback engine management systems are allowed. Stand-alone systems allowed.
LIGHTS/STREET EQUIPMENT: Headlights, turn signals, horn, and taillights must be retained in stock condition. One headlight can be removed for air induction.
BRAKES: All cars must have four working hydraulic brakes, and in good working order.
COOLING SYSTEM: No electric water pumps. Electric fans allowed. Must use overflow/catch can 1-pint minimum NOT be mounted in front of tires or with overflow line pointed at tires.
TIRES/WHEELS: Cars running 11.99 or quicker must have metal valve stems. Tubes permitted. No skinnies allowed on forced induction cars in this class. NOTE: absolutely no mini spare tires or non-speed rated tires may be used.
FWD 4 Cyl N/A w/slicks
FWD 4 Cyl Forced Ind. with DOT Approved tires.
RWD 4 Cyl Forced Ind. DOT Approved radials only
AWD 4 Cyl Forced Ind. Dot approved radials only
FWD 6 Cyl Forced Ind. DOT Approved radials only
FWD 6 Cyl. N/A w/slicks
NDRA approved Drag radials FWD/AWD cars: Max rollout allowed will be 82 inches.
BFGoodrich: G-Force and Comp T/A tires
Dunlop: Direzza
Nitto: NT555R.
M & H Trackmaster Drag Radials
MT Drag radials
NDRA approved DOT Street Tires FWD cars: Max rollout allowed will be 80 inches.
M & H Racemaster
NDRA approved Slicks FWD cars: Max rollout allowed will be 77 inches.
MT 24.5/9.0 max size.
M & H Racemaster 24.5/8.5 max size.
FUEL: Gasoline only. No fuel cells allowed on forced induction vehicles.
DRIVERS LICENSE: State, or Federal, or International drivers license mandatory.
COMPETITION LICENSE: A valid competition license mandatory for cars running 9.99 and quicker at a NHRA track and 9.50 and quicker at an IHRA track. (no exceptions!)
DRIVERS SAFETY EQUIPMENT: Any vehicle equipped with a roll cage or roll bar must be equipped with a padded head protector to be placed behind the driver's head mounted in such a way so as to help minimize the risk of whiplash. The cage or roll bar must also be fitted with padding in any area where it may come in contact with the driver's helmet. Padding with Ό inch compression or padding meeting SFI Spec 45.1 padding or better shall be used. No other forms of padding will be accepted.
FIRE SUPPRESSION SYSTEMS: Mandatory on all Pro cars, and Sportsman cars 9.59 and quicker. System must be SFI 17.1 approved for competition use.
HELMETS: Drivers of cars 13.99 or quicker must use a helmet that is Snell 95, 2000 SFI 31.1, 31.2, 41.1 or 41.2 spec. Any helmet that is modified in any way other than paint jobs shall be deemed unsafe and not suited for competition. Drivers must be wearing their helmet prior to entering the burnout area. The NDRA requires the use of Full Face Helmets and strongly recommends the use of the proper visor as well. A 38.1 head and neck restraint system required for all 9.59 and faster cars.
CLOTHING: 10.00-11.99: Drivers must wear jacket meeting SFI 3.2A/1.
SEAT BELTS: All cars that require a roll bar must use a 5-point SFI 16.1 driver restraint system equipped with a quick release system.Belts must be mounted to the frame or cross member or in a reinforced mounting point so that all connections are in a direct line with the direction of the pull. Cars requiring a sfi 16.1 drivers restraint system must have the belts updated 2 years from the dates stamped on the SFI belt tags. Cars using OEM type seats may route the crotch strap in front of the seat rather than through a hole in the base cushion.
PARACHUTES: Required for all cars exceeding 150 mph. Tech inspectors may inspect parachute for damage or wear at our discretion. Parachutes must be solidly mounted to frame and release housing must be no more than 12 from parachute pack and must be mounted in such a way to ensure smooth operation without failure. NOTE: any car running in excess of 150 MPH must pull the chute! If the driver doesn't pull the chute the run maybe DQ'd. If you're not sure pull the chute anyway!
Dunlop: Direzza
Nitto: NT555R.
MT Drag radials
M & H Racemaster
