Need help with 60"
Old May 30, 2009 | 11:05 PM
project504's Avatar
Default Need help with 60"
Hey
I've now have a couple of races under my belt I know how the car reacts out of the hole etc
I Just want it to get better.
right now I run a built N/A 84.5 by 89mm B20 vtec in a 2200lbs 89 civic SI
I run 23inch slicks, 1000lbs springs in the rear 550 in the front on Grond control Advanced designs shocks.
I use Hondata 300 I have my launch control set at 6600rpm and tire pressure at 10.5 psi ( before burnout)
here is a is a break down of my one of my runs
60' 1.843
330 5.200
1/8 7.913@91.17MPH
1000 10.260
1/4 12.248@113.30MPH
now I would love to get the 60' lower.
do any of you guys corner balance your cars? what % of the weight do you try for on the front end?
my tires stick out side of my fenders do you think if I flared the fron so I could lower the front that it might help?
raise launch?
any susgustions tips would help, I really would like to get her in the 11s.
thanks Justin
Old May 31, 2009 | 01:44 AM
DaveF's Avatar
Default Re: Need help with 60"
Originally Posted by project504
Hey
have you tried anything less ?
Old May 31, 2009 | 07:54 AM
project504's Avatar
not yet
if I lower pressure should I raise the launch?
thanks For the reply.
Old May 31, 2009 | 08:06 AM
TimKennard's Avatar
i launch at 6600 and my best 60' so far was with 8 psi hot tire pressure. just keep trying different tire pressures and different launch RPM. are you preloading the drivetrain?
Old May 31, 2009 | 08:26 AM
project504's Avatar
I don't use the e-brake to pre load
I've tried a couple of times and I just totally messed upo the launch.
I think I going to go on You tube see if anyone has any incar vid, of preloading.
Old May 31, 2009 | 08:36 AM
ExospeedAMcrx's Avatar
Your 60ft isnt BAD. but its not the best. Lower the tire pressure betwen 8-10. Go .5psi lower at a time and see how it reacts. You'll find out where it likes it and see the significant changes. soemcars will be alright with 9psi, some a little lower. Just have to trial and error yourself.
Old Jun 1, 2009 | 06:24 AM
eg5's Avatar
eg5
That MPH = easy 11.9
I used to ran 11.9 with 110mph , 1.67 60ft.
To run 11s , you need that 1/8 mile to go down to 7.5 - 7.6 sec
Drop the tyre pressure and see how it goes.
Old Jun 1, 2009 | 06:29 AM
project504's Avatar
so is tire pressure and launch the only thing I should be playing with?
do any of you cornerweight the cars?
deerman2701
Jan 24, 2012 09:24 AM
Cvekiux
Nov 26, 2008 05:16 AM
Jamied
Apr 29, 2006 08:15 AM
22psicrx
Mar 29, 2006 09:36 AM
itr-j
Sep 2, 2002 02:48 PM
