Need advise
Not sure if my question goes here but here I go..
I have a ek hatch w/full interior making around 330whp. I have 225x50x15s hoosiers qtp. I have a ls trans with a lsd and spinning the motor to 8500rpm. My question is what can I do to tach 4th gear out?
Fastest pass so far is 11.85@125mph with a 1.8 60ft. My 8th mile is 95.99mph. Do you think a taller tire would help I.E 24.5?
Or should I even be worried about it or?
I had the same issue with my spare LS trans. I hate them for high revving engines. I blew the oem diff in my GSR and while it was down I got a LS 4.266 final drive in it and WOW! It is MUCH better than that LS trans. I would recommend finding more hp and a new trans. Anything but a LS geared trans if you want to drag race it.
maybe its just me, but 125mph seems pretty high for 330whp and around 2500lbs.
anyway, you really need a different trans or diff. gearing. either a straight out gsr trans or a 4.4 or higher final drive in your ls trans if you want to go up to a 24.5.
you would need a smaller tire(less than the 23.xx inches that a 225/50/15 is ) to increase your rpm in 4th to tach it out, and i dont think going backwards is what you wanna do.
Stock GSR (w/LSD) and 24.5x9x13 slicks will do it. Low 11's for sure.
