Moran injectors
Old Mar 6, 2014 | 09:17 AM
c5R's Avatar
c5R
Default Moran injectors
Has any one here used the moran 235# or 275# billet atomizer injectors in a honda application im really thinking of taking the plunge and buying these as they are user serviceable and not much more than a set of id2000s
Old Mar 6, 2014 | 10:24 AM
pumafeet10's Avatar
Default Re: Moran injectors
always wondered why honda or 4cyl guys havent gotten into these
Old Mar 6, 2014 | 10:59 AM
nonvtecallmotor's Avatar
A few Honda guys use them with great success. Most of Honda game is all about monkey see monkey do bandwagon.
Old Mar 6, 2014 | 12:03 PM
c5R's Avatar
c5R
if you are a follower you will never be a leader
most honda guys are cheep also
Old Mar 6, 2014 | 02:59 PM
Gunmetal_B20_Hatch's Avatar
Theyre **** IMO... Had a guy with a pro-mod car trying to get them to work with his setup. Always had inconsistencies and multiple injector failures. The longest a set would last him was about a dozen dyno pulls. Never made it off the dyno with them. Im not sure what he switched to, but the car hasnt had a single injector failure since he switched. Methanol fuel BTW.
Old Mar 6, 2014 | 03:06 PM
redboost10's Avatar
^^^what was happening to them? Just quit? Or did they start getting more and more inconsistent? What did Moran say about the issue?
Old Mar 6, 2014 | 05:31 PM
2fastGSR's Avatar
King of the One Liners
We use them in our sfwd integra.
We did have an injector fail, Moran was quick to replace it.
Old Mar 6, 2014 | 06:04 PM
13173's Avatar
Thank you Rick for saying that. Truest thing I have read all day online.
Who puts a Pro Mod engine on a dyno and does dozens of dyno pulls?
Old Mar 6, 2014 | 07:17 PM
SwappedTURBOegg's Avatar
were the failures old injectors? there local to me,and more than willing to help anyone with a 4cyl.
Old Mar 7, 2014 | 03:48 AM
Turbo-LS's Avatar
I started looking into these my self but several People said they were inconsistent. They would tune a part of the map and get a/f set make another pull and those same fields would be off again and have to adjust. What inconsistencies are other people seeing? Do they come with a latency data sheet?
Old Mar 7, 2014 | 06:08 AM
c5R's Avatar
c5R
so inconsistencies is what people are saying is the problem. I have reason to believe that the latency/voltage offset were not setup properly were any of these injectors that were having issues ever put on a test stand and flowed/checked?
Old Mar 7, 2014 | 06:21 PM
turbo-2nr's Avatar
Would be my guess as well, most people just expect to just put them in and they work, tons of domestic guys run them with much success mainly in a staggered setup with small injectors
Old Mar 7, 2014 | 08:05 PM
Turbo-LS's Avatar
Question is do they come with latency/voltage offset tables? I was told they didn't which was the issues I'm sure. If you don't set latency tables it will be very inconsistant.
Old Mar 8, 2014 | 07:37 AM
boostedh22a's Avatar
I'm sure they arent making dozens of full power pulls but it's not uncommon to have pro mod engines on the dyno.
Old Mar 8, 2014 | 08:04 AM
jc@douglas's Avatar
I have a set of the 325's that miller should be tuning in the next couple weeks and I can come back with some feed back. I was running the siemens 220's however I ran out of injector on E85 and don't want to do a dual rail setup. I figured these were worth a shot, if it doesn't work out dual rails and ID's are in my future. I will report back once retuned with them.
Old Mar 9, 2014 | 06:17 AM
jc@douglas's Avatar
Also this is how they told me to set the motec up before I start tuning. This might be of help to some people.
Old Mar 9, 2014 | 05:37 PM
13173's Avatar
I live approximately 10 driving minutes away from Sonny Leonard's shop. I can hear them dyno engines occasionally at my house. I know that some are ran on the dyno. The guys that I know that run a Pro Mod are a little lower budget compared to some teams. I am not sure they have ever had an engine of theirs on the dyno.
I have seen many sets of Moran Injectors at the track; on cars that are pretty high budget in my opinion. Way to high of a budget to buy junk parts, if you know what I am saying. If they sucked like the guy said that supposedly knows a guy who couldn't keep them on his Pro Mod then I think big budget race teams would not use them.
Old Mar 10, 2014 | 09:49 AM
c5R's Avatar
c5R
Jeff let me know how they work out for you
Old Mar 20, 2014 | 04:08 AM
c5R's Avatar
c5R
Jeff how did it go?
Old Apr 4, 2014 | 08:28 AM
jc@douglas's Avatar
Sorry c5R, things got kinda crazy in my schedule. I plan to have the car up and running tomorrow on them and then figure out a time to get it retuned on them.
Old Apr 4, 2014 | 10:49 AM
Bugermass's Avatar
The inconsistency is from the ECU side. These injectors require quite a bit of current and peak time to fire properly. Most people run ECUs with poor drivers that are not adequate for handling this kind of load, and or, you cannot adjust the peak and hold times. This makes for sloppy injector handling..
Old Apr 4, 2014 | 10:53 AM
Bugermass's Avatar
How much power were you making? I've done 1000HP on E85 with the ID2000s around 70% duty cycle, and the Siemens 220s flow more than the ID2000s by about 300-400CC at the same pressure.
Are you sure its not a pump issue?
Old Apr 4, 2014 | 02:19 PM
Turbo-LS's Avatar
What would be an adequate ecu to run in order to control these injectors or an adequate peak/hold driver.
Old Apr 5, 2014 | 02:46 AM
narfdanarf's Avatar
I was always under the impression that the Moran injectors are rated for super high rail pressures for use with mechanical pumps....IE at "normal" base rail pressures the Moran's only flow like 100lb/hr.
Fuel Injector Clinic
Apr 12, 2013 09:48 AM
RattyTuned
Feb 6, 2012 02:52 PM
K i l l a B e e.
Dec 19, 2008 02:28 PM
9SECQTR
Jul 3, 2004 08:31 PM
