May F/S Thread
IF INTERESTED CALL 973)390-2982
turbosmart 48mm wastegate $250
GSR - victor x edelbrock intake manifold $250 or best offer
Professional Products 68mm throttle body $150
Precision injectors 1200 - $320 shipped in the U.S
Complete DOUBLE BOSCH fuel system, comes with all fittings, filters and stainless steel braided lines feed and return, red golden eagle fuel rail, aeromotive red and silver regulator, Everything is all put together all u gotta do is intall it $1100
aem ecu obd1 1040 box - $850 or best offer
toda oil pump gear and ati pulley for bseries comes with belt and trimmed cover 350$ Perrin boost control solenoid 25$ valve cover with -10 45s 100$
Means of contact: PM OR (TEXT 301-SIXFIVEFIVE-699TWO)
p28 that has been prept for s300 with pwm installed boost by gear SOLD!!!!!
Real skunk2 springs and retainers used for 6000miles on type-r cams $200obo
skunk2 dual bend short shifter used $100obo
p28 chipped for crome SOLD!!!!!
Guest
Posts: n/a
Still have my chassis thanks to a flaker, slacked on getting it back up here. I am offering a package deal with my electronics/random parts if you're interested in something along those lines as well.
Someone please do this chassis some justice
What you see is what I have, anything else pictured that isn't listed is likely gone.
Thanks!
List of parts:
Chassis: $12,000
• 25.5 spec (not yet cert’d, built by NRG to pass cert) 1992 Honda Civic Si
• Strange Rear shock/hub/brake combo. 90lb springs. Double adjustable.
• JAZ 3 gallon fuel cell
• Charge pipe with 2 downstream injector ports
• Kirkey pro-drag seat (mounted to fit into car)
• Franks fiberglass front end
• Franks fiberglass doors/rear hatch
• Carbon fiber sunroof plug – not installed since fabrication is not complete
• Weld Magnum skinnies w/22” MH tires
Electronics:
• AEM Serial - Custom fuel pressure gauge to read higher pressure (above 200 psi) – 250 (Also reads 5 other channels all in one unit)
• 2- AEM Water/Oil temp gauge – 175
• AEM UEGO sensor (external) (Reads low enough for methanol) – 160
• ARC electronics Switch panel w/firewall mounted panel - 300
• 128 pin cannon plug w/1 backshell and pins - 250
Universal Parts:
• Weld Magnum fronts 15 x 10. 4” backspace, 5 x 4 ¾ bolt pattern. (Chevy) Used 28 x 10.5” tires on them
• XS power 16v battery – 225 (may be surcharge for shipping due to weight)
• Safecraft Fire suppression system
• 2 550lb springs and 2 450lb springs. 2.5x8” – 100 a set shipped
• -8 Earls Black fittings – Lots of misc plus hose
• Kinsler K-140 Fuel Pressure Regulator - 350
• Kinsler monster mesh fuel filter -12 in/out - 125
I also have push lock fittings from Legris and about 20' of 1/4 line as well. Black line, fire jacket, and black/nickel plated fittings. You can sort of see the stuff in the last picture near the WG's and chassis. Not sure on a price but I'll take inventory and post up.
HOSE/FITTING Inventory:
-8:
Straight - 2
45* - 2
60* - 2
90* - 4
120* - 2
Hose - 10 feet (I think I've used 3 feet of this tops)
-10:
Straight - 2
45* - 1
90* - 1
-12:
Straight - 2
45* - 1
90* - 2
120* 1
Reducers 10 --> 8 (Qty. 2)
I think there is a misc -6 90*, straight, and maybe 3 feet of new line as well.
Also should have a few feet of -12 left as well.
40' Trailer - 8k with 5th wheel hitch
Thanks!
List of parts:
Chassis: $12,000
Electronics:
Universal Parts:
-8:
Straight - 2
45* - 2
60* - 2
90* - 4
120* - 2
-10:
Straight - 2
45* - 1
90* - 1
-12:
Straight - 2
45* - 1
90* - 2
120* 1
I have a chipped obd1 vtec ecu. I will set the redline, vtec engagment, 2step, and shift light at what ever RPM you want. 516-330-6190 call or text
In order for the 2step to work you have to have a working vehicle speed sensor.
$130 shipping is extra $10
located in inwood, ny 11096.
From: east coast performance and tuning, jacksonville, nc
this is a turn key, ready to race sfwd car with 24ft trailor. im lookin to get 20,000.00 you won't find a better deal.
93 honda hatchback (clean title)
24ft motortrack trailor (clean title)
nhra cert 10point cage
erl decked b16 block (1.9l) block
stock crank
crower rods
mahle 9.0 to 1 pistons
gsr head full ported and polished
supertech valvetrain
beehive lma's
skunk2 pro2 cams
70mm blox tb
jg intake mani
precision 1600cc injectors
aeromotive fuel reg
aeromotive elimanator fuel pump
-10an fuel feed
-8an fuel return
afi t4 twin wastegate topmount
borg warner s372 turbo
twin turbo smart wastegates
t1 gt3 intercooler
t1 catch can
golden eagle shatter shield
spec triple disc clutch
titon valve
par gear set
quaife lsd
dss 5.9 axles
avid solid mounts
avid traction bars
custom catch pan
mishimoto radiator and hoses
m&w pro10 ignition box
aem injector driver
aeromotive fuel pump regulator
hondata s300 boost option
there is a lot more call me a 910 938 7223 ask for jeff
stock crank
crower rods
beehive lma's
skunk2 pro2 cams
70mm blox tb
jg intake mani
aeromotive fuel reg
-10an fuel feed
-8an fuel return
t1 gt3 intercooler
t1 catch can
titon valve
par gear set
quaife lsd
dss 5.9 axles
avid solid mounts
avid traction bars
custom catch pan
aem injector driver
Brian Crower spring/retainer kit. Pulled from my personal car made 650whp with these on a ls/vtec had 7k on them. Titanium retainers with dual valve springs and locks. $250
REV intake and exhaust valves +1mm on intake and exhaust 7k on them. $175
ITR camshafts intake and exhaust cams. SOLD!
5” Vibrent silicone coupler with 5” pipe. Was on a full-race top mount with a s372.. $75
Moroso oil pump pick-up for LS SOLD
Intercooler brackets… made for a precision 600 intercooler. $20
Working resister box $20
Hondata GSR intake gasket SOLD!
NEW MSD GSR dizzy cap made for use with external coil… $30
Integra center console $20
B-series OBD2 alt works perfect SOLD, B-series starter brushes going bad, good core $20
Autometer shift light unknown condition $20
FS: H22 skunk2 pro3 cams with golden eagle cam gears, only used on the dyno for about 10 pulls!
The cams are $700 brand new and the gears are $200 brand new, so I'm looking for $650 shipped (48 states only) for the pair.
pm me with any questions, thanks!
RLZ cnc H22 cylinder head: $1800.
this is my personal race head. it is completely assembled w/ Ferrea valves (+1mm intake) and skunk2 pro series valvetrain. it was just freshened up by RLZ before the season started and has only 4 passes on the valvejob. this head has been setup w/ clearance to run pro3 cams w/ the oversized intake valves.
Carrillo A H22 rods used: $500.
NEW Cometic gasket H22 90mm bore .030 thick: $50.
I would trade for:
- t3/44 manifold (preferably full race)
- stc reaper turbo
-matching downpipe
-tial 44mm gate (preferably silver)
<U>FOR SALE:</U> All prices do not include paypal fee or shipping. THROW ME SOME OFFERS!
2001 GSR head: supertech nitride coated oem size valves, supertech bronze valve guides, supertech valve seals, supertech hd100r springs, supertech retainers.
-New Borg Warner/Bullseye Power S366 T4 .83a/r Divided Housing Turbocharger $1200
-New Custom 4" Downpipe, coated, for this turbo $400
-New Full Race T4 ProAm Divided Top Mount Manifold $1250
-New Custom Dumptubes, coated, for this manifold (two merge into 1) $200
-New 3" Intercooler Piping for EG/DC, tial flange, powdercoated pearl white, beadrolled $350
-(2x)Tial 44mm Wastegates (both have brand new diaphragms) $340 each
-New M&W Pro10 Kit w/ Crane PS92 Coil and custom T1 Plug n Play Harness $700
-New Custom EG/DC 4" Stainless Exhaust, coated, with 4" burns muffler (fits awesome! w/ great ground clearance!) $650
-Competition Clutch Twin Disc (used on dyno only, like new) $1000
-New Full Blown Dual Walbro Fuel System Kit *Complete with all fuel lines (-8,-10) and fittings necessary. $700
Cheaper pricing if buying multiple parts. Will give big discount if you buy the turbo setup as a kit (turbo, manifold, downpipe, wastegates, dumps, piping)
Please BUMP if viewed. If interested in anything, email me iconz116@hotmail.com
- stc reaper turbo
-matching downpipe
This sucks, but it has to go. i torn my left arm off pretty much, in jan. had it repaired, have been out of work since then and it is past the 3 month my work has to give me off with holding my job, im not able to go back so then fired me. now i need cash to pay my bills.
Its a ex Hot-Rod car, it only needs a engine and harness. Has a franks fiberglass 2 piece front end and doors, prostock wing, strange rear suspension.
It comes with new 28x10.5 MT slicks, new 26x4.5 Skinnys, New Aeromotive Fuel system with lines, pump, regulator, filters.
It has a Nitro driveline in it, i sent all the parts to Rob moore to go through, he replaced all the shafts and joints, i also got a new spool and studs. still have the old stuff as spares
The trans is assembled, it has a prodrive final drive, phantom cuff, welded case, cryo treated 1-4, and new syncros.
Extras- 5gl intercooler tank, fittings, piping, New M&R window net, etc.
10,000 firm will not split driveline from chassis
motor is currently blown in the car dont know how bad all i know is i have a piece of the piston and of the rod in my hand
body:
96 ek hatch (freshly painted)
cf hood
10pt roll cage
safety seatbelt harness good till 2014
painless switch panel
autometer rpm gauge
aem uego wideband
aem temp gauge
aem boost gauge
96-98 blackhousing ctr headlights
ctr lip (front and back)
Under the hood:
k20z1 20k
sk2 stg 2 cams
xcessive manifold (ported by certified racing)
full race t3 manifold
44mm tial wg
hks bov
prescision 6262 .82 bb billet
3inch dp
prescision 750ic
dual bosch 044 pumps
new tank (sumped)
-10 fuel lines
id1000s
mishimoto half size radiator
ktuned idle pulley kit
hondata kpro
ep3 5spd tranny (freshly rebuilt with lsd)
36mm hubs and axles
exedy twin disc
suspension:
-ksport drag
-all new poly urethane bushings
-sk2 upper front and rear lower control arms
-ktuned traction bar
random details:
-car went 11.1 @ 137 2.7 60ft falling on its face off the line because i didnt build enough boost off the line
-everything has exactly 4 dyno pulls 2 burnouts 1 full pass and a few start ups
-motor blew because of 2 reasons 1. no boost controller running 19lbs spiking to 26ish 2. motor was the same motor i was beating on all of last year wen it was all motor
i will entertain trades call or txt 6466961055
body:
cf hood
10pt roll cage
autometer rpm gauge
aem uego wideband
aem temp gauge
aem boost gauge
Under the hood:
k20z1 20k
sk2 stg 2 cams
44mm tial wg
hks bov
3inch dp
prescision 750ic
new tank (sumped)
-10 fuel lines
id1000s
hondata kpro
36mm hubs and axles
exedy twin disc
suspension:
-ksport drag
random details:
FS Precision Billet 6768 Ball Bearing .96 Exhaust Housing Anti Surge H Cover(4in\3out)
Has a few passes and dyno time on it mint condition - $2000
3.5 inch v band downpipe with flex section will work on a full race and afi top mounts.$200
3.5 inch aluminum exhaust for EK hatch with vibrant race muffler all v bands (may fit other chassis)
prefer local pick up-$600
Will workout package deal for all pieces
we have a 2006 Patriot Enclosed 20' Car Trailer for sale
we have had this for the past 3 years or so and it has been really good to us -- we are just looking to upgrade to a larger trailer and this one needs to go
pictures are worth a thousand words so check out the pictures included or email James@IPGParts.com for pictures
we just had the wheel bearings gone through and they are in good shape -- the trailer includes the 4 good tires already installed and 2 spare rims/tires
(car, parts inside the trailer, etc are not included in the sale)
$4200 takes it
email -- James@IPGParts.com
phone -- 407-324-4684
$4200 takes it
COMPLETE PART OUT!!!!!!!!
M&W Pro10 ignition with T1 harness with coil-$500
AEM Version2-$850
Edlebrock Victor X (B16/ITR) bored for a 76mm TB-$200
BorgWarner S372 T4 twin scroll with race cover-$900
BorgWarner S366 T4 twin scroll-$750 with 4inch downpipe
Custom Made T4 twin scroll top mount Manifold-$600 ($1000- with 2 tial 44mm gates)
Hasport solid B series mounts-$300
1994 clean title civic coupe race car shell.... $3800
comes with..........
Exospeed 3 piece front end
black houseing headlights with amber corners
50/50 tail lights
10pt cage
custom cluster with Auto meter, tach,oil pressure, water temp, EGT, and Boost gauges
battery relocated to trunk with a sealed box and all wiring with kill switch
cobra racing seat with RCI 5pt harness
kens kustom staging brake
kens kustom brake booster delete master cylinder
braided steel clutch line
rear disk swap with new cables
rear camber kit
skunk2 front camber kit
Bseries shift linkage with energy bushings
skunk2 drag launch coilovers with KYB AGX sturts
sumped tank with aeromotive A1000 pump -8 feed -6 return 2 filters
body is probally 7-8 outta 10 paint is about 4yrs old no major body damage no rot
interior is clean still has all panels, carpet and headliner in the car
im not parting out the shell.......
all prices include shipping in the US except the shell
if you want pics just ask and I'll get em to u ASAP
AEM Version2-$850
50/50 tail lights
10pt cage
rear camber kit
Skunk2 pro series valve springs. (120 shipped)
earls ss ls/b20 vtec oil line kit. (60 shipped)
Toda racing cam gears. (200 shipped)
Blox red cam seal. (20 shipped)
HDI racing FMIC. (250 shipped)
2 OBD2 B series alternators. (45 shipped each)
BLOX bnib billet 76mm throttle body (220 shipped)
other stuff pics available upon request...
